Quad t/bodies on smallport 16v
Postby trdnut » Mon Aug 08, 2005 9:50 pm
Hi i'm sure this has been done already just needed to know what is needed besides itake manifold and what should be done e.g. with the vacuum hose?
does anyone know of a place that manufactures the inlet manifolds? 8)
trdnut
Postby Bazda » Mon Aug 08, 2005 9:58 pm
give karl skewes or drifter4ag a pm, they know where to get them from
Postby suberimakuri » Tue Aug 09, 2005 4:03 pm
i have alloy water cut plates for small port head to 20v silvertop ITB's.
Just need tubing, then weld and drill and tap.
Need brake booster fitting and pref use all 3 other ports for vacuum for fpr and ecu.
suberimakuri
Postby ChaosAD » Tue Aug 09, 2005 7:01 pm
Im doing the same thing on my bluetop.
I used a webber manifold wth adapter plates.
The bluetop TPS swapped straight over.
But what do you guys do about idle control?
ChaosAD
Postby suberimakuri » Tue Aug 09, 2005 7:04 pm
make the throttle bodies a little open so it idles.
no need for cold idle up.
itb's like a little throttle opening when starting so they get some air.
suberimakuri
Postby trdnut » Tue Aug 09, 2005 7:22 pm
I hate asking the dumb questons, :roll: but what exactly did you do for the vacuum hoses?
trdnut
Postby ChaosAD » Tue Aug 09, 2005 7:29 pm
Do you replace the air temp sensor with a resistor? or is there some way of integrating it?
And im guessing you guys just ditch the cold start injector
For vacum hoses most people just drill/tap a hole in each runner put a signal dampner on each and tee them all together.
Do they have to be balanced when putting them on another engine?
Or are they balanced enough from factory?
ChaosAD
Postby trdnut » Tue Aug 09, 2005 8:14 pm
yeah i would just ditch the cold start injector.
Sounds like a sensible idea bout tee-ing the vacuum together. Good point bout the tem sensor!
trdnut
Postby 3T-Rona » Tue Aug 09, 2005 9:08 pm
got a price and possibly a pic Karl?
3T-Rona
Postby suberimakuri » Tue Aug 09, 2005 11:38 pm
yes, tee together, you need a dampener so that the map signal doesn't pulse.
3trona they are just water cut plates, imagine a 10mm thick alloy plate that is the same shape as the gasket for the smallport head, and then another one the perfect shape for the 4 20v quads, ports also water cut into them so all you have to do is drill and tap and connect the two plates with some alloy pipe. $120.
ditch cold start injector.
hang air temp sensor around on manifold, it'll read same temp as air going into motor.
By the time one picks up itb's, I don't think they are balanced.
balanced enough from factory though, MS can run them sweet, might just turn idle up for all 4.
suberimakuri
