by suberimakuri » Tue Aug 09, 2005 11:38 pm
yes, tee together, you need a dampener so that the map signal doesn't pulse.
3trona they are just water cut plates, imagine a 10mm thick alloy plate that is the same shape as the gasket for the smallport head, and then another one the perfect shape for the 4 20v quads, ports also water cut into them so all you have to do is drill and tap and connect the two plates with some alloy pipe. $120.
ditch cold start injector.
hang air temp sensor around on manifold, it'll read same temp as air going into motor.
By the time one picks up itb's, I don't think they are balanced.
balanced enough from factory though, MS can run them sweet, might just turn idle up for all 4.
