Spark plugs dying
Spark plugs dying
Postby Caveman » Tue Aug 09, 2005 8:52 am
Hi
my mates car keeps killing spark plugs. We've replace about 2 sets in 4 weeks. Did a compression test and all cylinders are 150psi after about 4 cranks.
The old spark plugs oil up then died, they new ones have gone really white. WTF?
The engine is a SR20DET with a T28.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby Ae92typeX » Tue Aug 09, 2005 11:06 am
sounds like a fuel issue, assuming you have used the same heat plug both times
Ae92typeX
Postby THA SHZ » Tue Aug 09, 2005 11:11 am
sounds like u are running to rich and foulin the plugs , are u givin it a goiod run or just small usage ? :?
THA SHZ
Postby EVLGTZ » Tue Aug 09, 2005 11:13 am
What plugs ya running in it? JUst the stds?
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby EVLGTZ » Tue Aug 09, 2005 11:14 am
THA SHZ wrote:sounds like u are running to rich and foulin the plugs , are u givin it a goiod run or just small usage ? :?
yeah but second set of plugs are all white so looks the opposite for them....crazy
EVLGTZ
EVLGTZ
Postby ATAl » Tue Aug 09, 2005 12:21 pm
Doesn't white plugs mean they are getting way to hot, probably because of running lean. They go black when running rich.
You best check out the a/f mixtures or your going to be up for more than just spark plugs if it is running very lean.
ATAl
Postby Caveman » Tue Aug 09, 2005 3:57 pm
Yes its very odd.
I think the turbo may be on its last legs causing all sorts of problems. Other than that theres nothing else much wrong with it.
I might check he isnt using 91 8O I wouldnt put it past him lol
I'll find out more information tonight.
AW11 Track Toy
Caveman
