1uz with link - no cold start? also... need a/c
Postby liftback » Sat Aug 13, 2005 9:03 pm
Whenever i start the supra up, it wont idle until it has warmed up (to about 20-30C), so does that mean that the link hasnt been setup for cold starting? can i take it to a tuner and have it programmed for cold starting?
also, the a/c wasnt hooked up when the engine was put it. the pump is still there, so will it be very hard to get it hooked up? the car had a/c originally.
'95 Ce108 Mule
'98 Suzuki TL1000R
'98 Suzuki RG150E
Whats all this then?
liftback
Postby loose_unit » Sun Aug 14, 2005 12:56 am
As far as i know all the link does is add in extra fuel when its cold, theres no idle up or anything, unless you have set one up with the link setup.
My starlet with a link idles at about 5-600 rpm when its cold, you learn to live with it :D
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby liftback » Sun Aug 14, 2005 2:30 pm
thats the thing though... i doesnt seem to be throwing in any extra fuel because it just stalls when cold - so i need to have it programmed to throw in extra fuel when cold.
'95 Ce108 Mule
'98 Suzuki TL1000R
'98 Suzuki RG150E
liftback
Postby vvega » Sun Aug 14, 2005 2:47 pm
if it wasent throwing extra fuel in it wouldnt start.....
you will find the cold start solienoid is not working or isnt hooked up
i do not think the normal link can do the 3 pin varable idle valve like in the iuz so you may have to just get something made or make on up yaself :D
v
vvega
Postby liftback » Sun Aug 14, 2005 2:49 pm
Ok cheers for that, I might take it somewhere that deals with links once ive got the clutch sorted.
'95 Ce108 Mule
'98 Suzuki TL1000R
'98 Suzuki RG150E
liftback
Postby matt dunn » Sun Aug 14, 2005 9:57 pm
liftback wrote:thats the thing though... i doesnt seem to be throwing in any extra fuel because it just stalls when cold - so i need to have it programmed to throw in extra fuel when cold.
I think you'll find it's not throwing in any extra air rather than fuel,
as a cold engine needs extra air when cold to make it idle,
and as said you will probably find that the link is not controlling it.
Matt
Postby liftback » Mon Aug 15, 2005 1:31 am
Sweet as. When i get some cash ill take it somewhere to get re-tuned anyways (because i dont really know what state of tune its in at the moment), and see what can be done about the cold start at the same time.
'95 Ce108 Mule
'98 Suzuki TL1000R
'98 Suzuki RG150E
liftback
Postby Punter » Mon Aug 15, 2005 2:01 pm
Let us know what happens my dad is having the same cold running problems in his rally car running a nissan V8 with a link. Runs really well when warm though
I love deadlines. I like the whooshing sound they make as they fly by.
Punter
Postby Tukumi » Mon Aug 15, 2005 3:12 pm
A cold engine does need more fuel to have correct mixtures at idle. Although it shouldnt run much richer than a hot engine due to most of the extra fuel that your putting in doesnt make it to the cylinder as it creates a film on the intake runners and ports due to the cold temp of the engine.
My flatmates s13 silvia with Lexus v8 doesnt run idle speed either but it still idles at 800rpm when cold. There is alot of varibles in cold starting of engines which makes it kinda tricky for someone not in the know to set them up properly.
What is done to your 1uz engine as we have a good base map tune for a fairly standard setup with exhaust and filter.
Phil
AE85 4AGTE, 11.9@115mph <--Watch this space 229kw at the wheels ***sold***
WWW.NZEFI.COM
WWW.DORIMONS.COM
Tukumi
Postby liftback » Mon Aug 15, 2005 3:18 pm
Oh when I say it doesnt idle, i mean it doesnt idle at all - as in it dies everytime its started - I have to keep my foot on the throttle and bring it up to aobut 1000rpm until its warmed up a bit before it will idle properly.
1uz in an s13? niiice...
The engine is pretty stock, just a pod and exhaust (although it doesnt have extractors at the moment - going to sort that out and have the exhaust done properly before i take it in to get tuned).
'95 Ce108 Mule
'98 Suzuki TL1000R
'98 Suzuki RG150E
liftback
Postby Stephen » Mon Aug 15, 2005 8:46 pm
My supra was the same the first 2 tuners didnt get the cold start right they made it sound like its to hard to do.The guy doing my tuning now has got it better.The problem is they only really get 1 chance a day at changing the tune on a cold start.So it takes quite a few days to get it right.
Stephen
Postby liftback » Tue Aug 16, 2005 12:42 am
Who does your tuning?
'95 Ce108 Mule
'98 Suzuki TL1000R
'98 Suzuki RG150E
liftback
Postby RedMist » Tue Aug 16, 2005 10:28 am
As per VVegas and Matt's post. Its not a fuel problem. You can't tune it out. Its the fact that you can't drive the 3 wire stepper motor with the link for idle up.
You can alter cold idle fuel which will give you more or less fuel dependant on how you change it. However all this will do is make it harder to start and you'll still end up putting your foot on the acclerator until it warms.
You may be able to drive the the 3 wire idle up motor with a stepper motor driver from Jaycar, but I don't know enough about those controllers to be able to dictate thier function.
In addition if your looking for AC idle up, (IE the car doesnt stall every time the compressor engages) then you'll have the same problems as above, as it uses the idle up motor. AC Idle up is only available on the Link Plus.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Boldy » Tue Aug 16, 2005 10:50 am
trying poking around on http://www.lextreme.com/forums/ there are people there using aftermarket ecu's that are having/had your exact problem.
Boldy
