silvertop turbo?? help please
Postby LVN LOW » Mon Aug 15, 2005 11:55 am
can anybody help me with any information on how to setup a silvertop turbo for my ae101 levin. what turbo to run? can u use the standard ecu?anything will help.![/u]
if you cant win look spectactular
LVN LOW
Postby Andy from the block » Mon Aug 15, 2005 12:12 pm
just a quick reply regarding the turbo.
There is a Series 4 RX7 turbo on trademe
http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Performance/Turbos/auction-33029650.htm
with a buy now of $150, same price I paid for my one on my white car.
Pretty good turbos according to people who have used them on
4ages before. However you may want to look into fitting a RB20
exhaust housing since the factory housing on that turbo is considerably
larger and combined with the already large exhaust wheel would
be very laggy on a 1.6L engine.
Andy from the block
Postby Mr Revhead » Mon Aug 15, 2005 12:52 pm
rebuild with some 4agze pistons
TRD headgasket
link ecu
away you go.
Postby crnkin » Mon Aug 15, 2005 4:48 pm
either what warwick said, or just run a m10/ t25/t28, 8psi, stock ecu, theres a few tricks you can do with the fuel and unleash the awesome 4age power!!!!!!!!!!!!!!
deaf_homo "currrently yes"
crnkin
Postby Mr Revhead » Mon Aug 15, 2005 4:54 pm
id be careful running that much boost on the 20v compression, especially with the stock ecu
a stock 20v needs the timing backed off to run our fuel as it is....
Postby flygt4 » Mon Aug 15, 2005 7:36 pm
revhead was closest..to do it properly
standard gze bottom end
silvertop head
gtz gbox and driveshafts and some sort of lsd
choice of turbo.. tdo4,t25,t3 or if more power is the goal, tdo5,t28,vf24 or one em rx7 ones plus you'll need a manifold made up+intercooler+piping
aftermarket ecu
bigger fuelpump+injectors
it'll need to be tuned,standard gze bottom end are damn solid , are happy to run up to 20psi
its not cheap if you cant it yourself but all that said and done could net you just over 200kw atw depending on choice of turbo and tuning
flygt4
Postby Mr Revhead » Mon Aug 15, 2005 7:39 pm
cheapest way to do it is start with a 20v, 4agzes are waaaaay overpriced.
swap the pistons, and you have a ze bottom end anyway. fresh one too :wink:
also the stock "c" series box can actually handle some grunt. 250hp is one figure iv heard. certainly a hot 20v turbo will kill one, but look at what youll be making, and how youll use it to decide if its worth it.
also the "c" box has closer ratios....
Postby flygt4 » Mon Aug 15, 2005 7:44 pm
thats true warrick.. i think mine will clear 100km in 2nd revving it out past 8g on the gtz box.. cost of doing would depend on how much you could do yourself.. a person with moderate welding skills and good at sourcing the parts could do it very cheaply :)
flygt4
Postby crnkin » Mon Aug 15, 2005 11:32 pm
Mr Revhead wrote:id be careful running that much boost on the 20v compression, especially with the stock ecu
hmmm true, the comp is quite high, but would be an easy exercise to test out, and shouldnt be too bad, maybe a powerlink or similar would be a good idea
crnkin
Postby LoRolla » Tue Aug 16, 2005 12:17 am
Powerlink would be a good option. As for the turbo, t3/t4 8)
Current Ride: '87 7afte KE70 Wagon
Previous Rides: 4age ke70, '89 vr4 220kw, mx73 cressida, '90 Hilux Surf mud truck 16psi
PC Customs
Building it your way
PH/TXT: 021 201 5665
E-mail: heilynbell@live.com
For all PC/HTPC/Laptop repairs, mods, upgrades and custom builds
LoRolla
