hybrid turbo 205
hybrid turbo 205
Postby TRDmod » Mon Aug 15, 2005 4:44 pm
st205
im getting my turbo HYBRID ...
aparntly they machine the inside and enlarge it blah blah blah, ok fine
just curious, how much power difference should i notice or dyno from this mod by making the turbo hybrid and more efficient and larger capacity?
apprently it makes a difference...lets say everything is stock apart from 3inch exhaust and cold air intake
Domino's Pizza.....
TRDmod
Postby Lanius » Mon Aug 15, 2005 5:33 pm
Depends entirely what compressor they're using with the existing turbo housing. If you can find that out and post it, it will help a lot :)
FWIW, a CT26 with TO4e compressor is one of the most common upgrades around. Gives a fair bit more oomph, although it tends to make it a fair bit more laggy too.
Lanius
Postby Al » Mon Aug 15, 2005 6:24 pm
Since you have a ct20b this is a bit weird. I didn't know anybody did hybrids in NZ for them? I think anythonym did a gt30/ct20b hybrid at one stage? I might be mistaken however.
The ct20b in 2wd form can get 275+rwhp...not for very long but it can do it.....just ask my seals and bearings :lol:
Ask yourself what you want of the car in terms of driveability and power and buy a turbo to suit.
Al
Postby Twolitre » Tue Aug 16, 2005 4:26 pm
Have you got a downpipe yet or are you still using the stock cat?
A downpipe will probably give you a better hp increase then a hybrid turbo on the stock cat and much cheaper too.
Twolitre
