hybrid turbo 205
hybrid turbo 205
Postby TRDmod » Mon Aug 15, 2005 4:44 pm
st205
im getting my turbo HYBRID ...
aparntly they machine the inside and enlarge it blah blah blah, ok fine
just curious, how much power difference should i notice or dyno from this mod by making the turbo hybrid and more efficient and larger capacity?
apprently it makes a difference...lets say everything is stock apart from 3inch exhaust and cold air intake
Have you got the hots? for what's in the box with the dots? ..... 0800 30 40 50
Domino's Pizza.....
TRDmod
Postby Lanius » Mon Aug 15, 2005 5:33 pm
Depends entirely what compressor they're using with the existing turbo housing. If you can find that out and post it, it will help a lot :)
FWIW, a CT26 with TO4e compressor is one of the most common upgrades around. Gives a fair bit more oomph, although it tends to make it a fair bit more laggy too.
Lanius
Postby Al » Mon Aug 15, 2005 6:24 pm
Since you have a ct20b this is a bit weird. I didn't know anybody did hybrids in NZ for them? I think anythonym did a gt30/ct20b hybrid at one stage? I might be mistaken however.
The ct20b in 2wd form can get 275+rwhp...not for very long but it can do it.....just ask my seals and bearings :lol:
Ask yourself what you want of the car in terms of driveability and power and buy a turbo to suit.
Al
Postby Twolitre » Tue Aug 16, 2005 4:26 pm
Have you got a downpipe yet or are you still using the stock cat?
A downpipe will probably give you a better hp increase then a hybrid turbo on the stock cat and much cheaper too.
Twolitre
Users browsing this forum: Google [Bot] and 32 guests
