hooking up a shift light to a 4agze
Postby mad starlet » Mon Aug 15, 2005 10:13 pm
would somebody be able to tell me witch coil you wire a shift light up to in a 4agze cause it has two coils or if it matters witch coil u use
mad starlet
Postby CAMB01 » Mon Aug 15, 2005 11:26 pm
you'll need a tacho interface unit to convert the signals from the coils into one signal for your shift light to work. i'm using one from a VR4.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby beeker » Tue Aug 16, 2005 6:10 pm
CAMB01 wrote:you'll need a tacho interface unit to convert the signals from the coils into one signal for your shift light to work. i'm using one from a VR4.
what generation of VR4 is it ?
The newer v6 VR4 ?
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby Rick » Tue Aug 16, 2005 7:03 pm
Postby beeker » Tue Aug 16, 2005 8:10 pm
Are you sure that is the correct part ? 100% ?
06 RS4 Avant
beeker
Postby CAMB01 » Tue Aug 16, 2005 8:37 pm
No its from a 4cyl VR4 with 4G63T.
The 2 input wires get a signal from both negatives on the coils, the output wires into your tach or shiftlight. Easy as.
CAMB01
Postby mad starlet » Tue Aug 16, 2005 10:17 pm
so you need one off a 6cyl vr4
mad starlet
Postby Rick » Tue Aug 16, 2005 10:33 pm
CAMB01 wrote:No its from a 4cyl VR4 with 4G63T.
Postby beeker » Wed Aug 17, 2005 7:27 am
Purchased. Thx.
Any tips on wiring it up ?
06 RS4 Avant
beeker
