Random FXGT questions
Postby DRFTIN » Thu Aug 18, 2005 12:57 am
just picked up the new AE92 FXGT tonight and i got a few Q's...
is an auto car different in any other ways? (ECU, engine etc)
will a blue top computer run a red top properly? i know there are differences but not sure how the computer effects them
will AE82 clutch lines and pedals etc fit the AE92?
if i take the tail light section off the boot what will be underneath it? my sister has the NZ new version of the same car :cry: and it has no tail lights on the boot, which looks much better, just wondering if i can make it look similar
if i add some nawsss and some TRD and mugen stickers will i get 500kw more? :P
i know most of these things can be worked out if i get off my ass and try them, but hopefully someone can save me having to need to
DRFTIN
Postby Silent Knight » Thu Aug 18, 2005 9:09 am
ECU won't work as it's programmed for a different generation motor. Also you would need some serious hacking to be done afaik to be able to make the loom plug in.
The only difference between auto and manual would be box/diff/ecu etc. Things you wouldn't normally notice when just looking at the car but are different. When you are looking for visible differences between cars compare different models of the same car...
I'm pretty sure the pedals etc should work between the models and in the off chance that it won't there will be very minimal modification involved in making them fit. I'm not sure about clutch lines though as I don't know wether the AE92 is hydrolic or not...
Finally there are rumors that a rear quarter window TRD sticker has proven dyno results of around 45-50whp. TRD sticker across windscreen however will give better results as has been proven many times on the dyno aswel....
Silent Knight
Postby gepsk8 » Fri Aug 19, 2005 12:01 am
is that why my car seem lost that 45-50whp, and my mates car seems to be faster?
gepsk8
Postby Adydas » Fri Aug 19, 2005 12:12 am
i think genral rule of thumb is auto cars will lose a higher % of drive train loss than a manual.
So in short
yes thats why it seems slower..
Adydas
Postby trdnut » Fri Aug 19, 2005 5:53 am
the blue top computer will run the red top engine but you have to use the blue top injectors and dizzy and loose the cold start injector!
Did it before on an nz new ae82 went like a bomb!
trdnut
Postby DRFTIN » Fri Aug 19, 2005 8:29 am
trdnut wrote:the blue top computer will run the red top engine but you have to use the blue top injectors and dizzy and loose the cold start injector!
just what i wanted to know, cheers
the reason i ask is we've got a AE82 with a supposedly modified computer, i'm pretty sure the guy is a moron and its a standard computer but i wanted to try it and see what it went like
and my question about whether auto cars are different i was meaning is there a power drop or anything, like i've heard some auto cars have
DRFTIN
Postby trdfxgt » Fri Aug 19, 2005 9:09 am
iv put a small port red top in my ae 82 it goes better than the blue top did good mod to get a later model motor as alot of blue tops are starting to die
trdfxgt
Postby Alex B » Fri Aug 19, 2005 9:27 am
DRFTIN wrote:[the reason i ask is we've got a AE82 with a supposedly modified computer, i'm pretty sure the guy is a moron and its a standard computer but i wanted to try it and see what it went like
Crack it open and post a pic.
Postby CAMB01 » Fri Aug 19, 2005 7:36 pm
Theres about a 30% loss of power through an automatic transmission, and a 10% loss with a manual.
Toyota ECU's cannot be modified.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
