4age series
4age series
Postby Lamphant » Fri Aug 19, 2005 3:18 am
how many types of 4age's are they.....here in the caribbean (barbados) we only have/get 2 types which are the silver and blacktop (16v/20v) 4age's. i've seen in some other topics mention of blue tops and red-tops....... and was wondering what is the difference between these 4 "models" of the same engine
thanx
Lamphant
Postby Lloyd » Fri Aug 19, 2005 8:13 am
There is heaps of info around on the net about them. Do a google search for "4AGE generation" and see what you find.
http://www.users.bigpond.com/vidore/toy ... engine.htm
http://www.billzilla.org/4agstock.htm
Have a look in the tech section at www.club4ag.com too
Postby SIKTOY » Fri Aug 19, 2005 8:54 am
Not to mention the sticky at the top of this section ( Toyota Engine Stats - All you EVER wanted to know)
Pulled straight from there:
Engine Type Valv/Cyl angle Year Disp. BHP Torque [lb ft] Bore [mm] Stroke [mm] CR other remarks
4A-GE DOHC 4/50 83- 1587
4A-GE DOHC 4/50 85-86 1587 112@6600 97@4800 81 77 9.4:1 (Bluetop)
4A-GELU DOHC 4/50 86 1587 130@6600 110@5200 81 77 9.4:1 (Bluetop)
4A-GELU DOHC 4/50 86 1587 124@6600 105@5000 81 77 10:1 EU, (Bluetop)
4A-GELU DOHC 4/50 86 1587 120@6600 102@5000 81 77 9.4:1 (Bluetop)
4A-GELU DOHC 4/50 86 1587 115@6600 98@4800 81 77 9.4:1 cat, US version (Bluetop)
4A-GEC DOHC 4/50 88 1587 116@6600 110@4800 81 77 9.4:1 (Redtop)
4A-GEC DOHC 4/50 89-90 1587 116@6600 100@4800 81 77 9.4:1 (Redtop)
4A-GELC DOHC 4/50 88 1587 112@6600 100@4800 81 77 9.4:1 (Redtop)
4A-GELC DOHC 4/50 89-90 1587 115@6600 100@4800 81 77 9.4:1 (Redtop)
4A-GELU DOHC 4/50 90 1587 138@7200 109@6000 81 77 9.4:1 (Redtop)
4A-GE DOHC 4/50 90 1587 130@6800 102@5800 81 77 9.5:1 (Redtop)
4A-GE DOHC 4/50 91-92 1587 130@6800 105@6000 81 77 10.3:1 (Redtop)
4A-GE DOHC 5+VVT 91-95 1587 165@7800 120@5600 81 77 11.0:1 AFM, VVT (Silvertop)
4A-GE DOHC 5+VVT-i 95+ 1587 170@? 81 77 11.0:1 MAP sensor, VVT-i (Blacktop)
ALL MEN DIE, NOT ALL MEN TRULY LIVE!
Current: 80 SR Project,
Check Out My Profile, Including CURRENT Pics!
Previous: 90 GT Sedan, 85 FXGT, 77 SR with 18RG, + many more.
Pink shaved pussy pic!!!
SIKTOY
Postby Alex B » Fri Aug 19, 2005 9:18 am
cept blacktop not VVT-i like that says.
Postby Mr Revhead » Fri Aug 19, 2005 10:44 am
and silvertop not 11:1 compression....
check and double check
the misinformation on these engines on the net is astounding.
Postby Lamphant » Fri Aug 19, 2005 1:28 pm
thanx alot guys, i didn't kno that there were dat much different types of 4age's out there. but by the way tings look it seems as tho the silvertop is the way to go in terms of torque........
but which 4age series do yall guys prefer. we here in the Barbados only get the silver and blacktop, so there ain't much to choose from
Lamphant
Postby Mr Revhead » Fri Aug 19, 2005 1:34 pm
what do you intend to use it for?
racing? are you going to rebuild it at all? or just run it in a road car?
Postby Lamphant » Fri Aug 19, 2005 1:37 pm
most likely racing it. i kno that de 20valve is probably best kept naturally aspirated and stuff, but de flow characteristics of the head shows that it could be useful if FI, but de engine is goin to be used as a street racing, daily commuter
Lamphant
Postby Mr Revhead » Fri Aug 19, 2005 1:42 pm
then the best one is the silvertop. they go fine turbod, with lower comp pistons.
if you can afford it, a blacktop with silvertop rods would be good. or rebuild a silvertop with blacktop pistons and head.
for a racer you would be better off with the silvertop rods
Postby Drifter4ag » Fri Aug 19, 2005 2:18 pm
those stats are a load of tripe
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
JZX91 MARK II CHASER
Drifter4ag
Postby Mr Revhead » Fri Aug 19, 2005 2:20 pm
that about sums them up :lol:
Postby Lamphant » Sat Aug 20, 2005 12:34 am
so i guess that the blue and redtop engines are jus "economy" 4age's so to speak then
Lamphant
Postby Alex B » Sat Aug 20, 2005 12:36 am
why do you say that? They are just older technolody...
Postby Lamphant » Sat Aug 20, 2005 12:39 am
older technology? they were the first 4age series? explain dis a lil further cause i kinda "lost"
Lamphant
Postby CozmoNz » Sat Aug 20, 2005 12:41 am
they were...
but the non tvis redtop makes 100kw, which is what most 20v blacktops are making... some technology aye ;)
que redmist, whats that word again? Hem who?
Rayne For President!
CozmoNz
Postby RedMist » Sat Aug 20, 2005 10:29 am
*enter stage left*
Actually the small port has little to do with Helmholtz. It's to do with flow and velocity. The smaller the port the larger the velocity, the more fuel stays in suspension. But that's been covered a million times before.
My pick has always been the 16 valve non tvis redtop for power and a good span of torque, however its all application dependant. Bigports may be better for power at 10k RPM. Blacktop perhaps turbo?
Saying the above I'm hoping to get good power from my new Blacktop, surpassing my smallport.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Drifter4ag » Sat Aug 20, 2005 10:15 pm
anyone done back to back head swap with turbo app ?
ie big to small port .. dyno each way ?
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby crnkin » Sun Aug 21, 2005 4:41 pm
matt thats what im looking at doing, cept with a p+p smallport (stock valves rarara) and a stock bluetop, the P+p is gonna be fairly simple, similar to clints. Is a wee way off tho, either late this year or early next, if any difference i expect the bluetop to go higher, but im hoping money spent will come through on the day
deaf_homo "currrently yes"
crnkin
Users browsing this forum: Bing [Bot] and 4 guests
