4AGZE TO 4AGTE
4AGZE TO 4AGTE
Postby CAMB01 » Sat Aug 20, 2005 10:15 am
Hey all iv done a search and can't really find the info i need so don't bag me for this but what exactly is needed and what needs to be done to convert a 4AGZE to a 4AGTE?
The motor i have is a map sensored 4AGZE.
Any info would be appreciated.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Lloyd » Sat Aug 20, 2005 10:26 am
Inlet manifold for turbo (100kW Redtop or custom)
Exhaust manifold, dump pipe and exhaust
Intercooler and associated piping
Oil feed for the turbo (can use the oil pressure sender hole and T it to a gauge)
Oil return into the sump
Turbo itself
Gaskets etc
Its not too bad to do if you're starting with a GZE in the first place as the ECU is all ready for boost and so on
Postby EVLGTZ » Sat Aug 20, 2005 10:50 am
the 4agze MAP ecu's are ok for boost but not the best for a turbo setup. Have a max boost of about 15psi on them and also are setup for the s/c so the tune wont be ideal for 4agte. Its useable tho but to get best results I'd seriously consider going aftermarket.
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby IH8TEC » Sat Aug 20, 2005 7:54 pm
viewtopic.php?t=21876
thanks to matt dunn, put a little bit together if you scroll down, should be a sticky or sumthing.
