FWD and 4wd wheel offsets
Postby diss7 » Thu Aug 25, 2005 9:32 pm
What is the typical offset for an 8 inch wheel on a front wheel drive?
Just checked out my my partners Glanza, which has a 7.5 inch rim, and the only markings that could be taken as possibly being an offset were 29, and 66. But I doubt whether either of these are correct.
And similiar question. What sort of offset does a Celica/Caldina and a WRX take for a 5x100 wheel; similar to each other or completly different? Again for an 8 inch wheel.
Thanks
diss7
Postby diss7 » Fri Aug 26, 2005 6:04 pm
Does no one know? :?
diss7
Postby evil_si » Fri Aug 26, 2005 7:10 pm
im running an offset of 45 on my corona with a 7.5" rim, the wheels were designated for a subaru 4wd but work sweet
evil_si
Postby JT » Sat Aug 27, 2005 3:06 am
29 is quite likely to be the offset of the rims on the glanza. Any lower and the wheel would probably be rubbing on the strut being 7.5" wide.
JT
Postby diss7 » Sat Aug 27, 2005 11:19 am
Its not 29, you can see visually that doesnt stick out like a+29 would.
Ahwell
Cheers anyway.
diss7
Postby Ae92typeX » Sat Aug 27, 2005 11:25 am
http://www.rsracing.com/tech-wheel.html#backspace
use that link, it explains how to measure your offset easy enough; also has a quick refference chart which may help.
Ae92typeX
Postby aesc » Sat Aug 27, 2005 12:45 pm
On my AE101 ive got 17 x 7.5's with 40 offset and the only just clear the rear strut by 1-2mm. And with a very heavy load they occasionally scrape on the guards too.
I think you might be pushing to fit 8" rims on a FWD like a glanza
EX AE101 owner
2013 Ford Focus ST
aesc
Postby QikStarlie » Sun Aug 28, 2005 7:43 pm
they should be around 40 for a glanza. my starlet has 40 not much room on either side. think standard wheels are 35 or 38??
QikStarlie
