silvertop breaking engine mounts?
Postby trueno_20v » Wed Aug 31, 2005 6:33 pm
ive gotta ae101 trueno with a silvertop 4age in it and it has broken the 2nd drivers side engine mount (studs) within 4months, i have had a quick look at the front and gearbox mounts and they look ok but will have a better look at all the mounts 2mro. ?????
trueno_20v
Postby bad20v » Wed Aug 31, 2005 6:37 pm
The front and rear engine mounts are usually the first to go, especially coz its a FWD vehicle, but I've never had a problem with the side mounts.
Are you launching from the traffic lights too hard?? :?
Thank-You.
bad20v
Postby trueno_20v » Wed Aug 31, 2005 6:40 pm
Lol na not driving too ruff at all, weird aye there must be another weak/broken mount on the back maybe?
trueno_20v
Postby bad20v » Wed Aug 31, 2005 6:43 pm
I'd guess so. Might pay to get it up on a hoist and have a good look at all the suspension.
Thank-You.
bad20v
Postby trueno_20v » Wed Aug 31, 2005 6:47 pm
What am i looking for? didnt think suspension would have anything to do with it???? :?
trueno_20v
Postby bad20v » Wed Aug 31, 2005 6:54 pm
Just check everything:
Sway bar links and bushes
Front and rear engine mounts
Control arm bushes
Balljoints
There has to be something under there thats not working properly, putting strain on the other parts of the vehicle.
Take it to a recognised suspension company, they should be able to check it over for you at no cost. :D
Thank-You.
bad20v
Postby trueno_20v » Wed Aug 31, 2005 6:55 pm
Sweet man will do that thanks :D
trueno_20v
Postby bad20v » Wed Aug 31, 2005 6:58 pm
No probs, I've had both a silvertop and a blacktop, and have had to replace engine mounts on both. usually the rear engine mount. Good Luck. :D
Thank-You.
bad20v
Postby sergei » Wed Aug 31, 2005 9:04 pm
I had driver side engine mount stud broken off on my AE101, the reason that it broke off, was that i did 2 things wrong:
1) overtitghten nut on one of the studs
2) not tighten enough the second nut on the second stud
so when nut number 2 fall off because it was not tight enough,the number 1 stud broke off because it had too much stress on it... so I had to extract what was left of stud and put a new one (and new nuts).
Funny thing is I saw the stud flying off (about 1.5m in air) in my rear view mirror (and heard a few bangs, as it was bouncing off the belts, then chassis, then underside of the car).
Postby Mr Revhead » Wed Aug 31, 2005 9:14 pm
yeah check ya other mounts. ae111s are very good at breaking the mounts
Postby Bling » Wed Aug 31, 2005 9:42 pm
Mr Revhead wrote:yeah check ya other mounts. ae111s are very good at breaking the mounts
would have thought toyota would have made stronger mounts to harness the torque put out by the blacktop.... :wink:
Postby CozmoNz » Thu Sep 01, 2005 12:40 am
excactly, could go and upgrade those blacktop's.
Just use 4efe mounts, more torque after all >.>
Rayne For President!
CozmoNz
Postby bad20v » Thu Sep 01, 2005 11:38 am
Mawhahahaha!!! Even I have to laugh at that comment! :lol: :lol: :lol:
When I had my old ae101 trueno, I was working for a supension company called SAS, and when my front and rear mount broke, I replaced the bushes with a better designed and stronger type. And just a note, if anyone tells you to put urathane bushes in... tell them to f#@k off. Thats unless its a race car. :D
Thank-You.
bad20v
SOMETHING TO THINK ABOUT.
Postby TOYROTA » Tue Sep 06, 2005 2:50 am
I can pour brand new mounts out of harder nolothane at my work but to make it cheeper u can ring me and il take tham to work and do so (2-3 day turnover as the nolothane has to cook for 16hours once poured. 0211099237 scott.
im not on here that often so ring my phone.
Curre3nt rides-
1982 starlet kp61 4 door (in panel shop getting bare metal resto)
1980 tt132 corona wagon 3t t40 (daily doomsday machine)
TOYROTA
Re: SOMETHING TO THINK ABOUT.
Postby bad20v » Tue Sep 06, 2005 11:25 am
TOYROTA wrote:I can pour brand new mounts out of harder nolothane at my work .
And so rather than fix the actual problem, your just going to start a new one and charge him more for urathane mounts??? :? I really don't think a harder mount is the solution, especially made out of urathane which will make his car 'shudder' more at idle and won't last as long as a standard rubber mount should.
Thank-You.
bad20v
Postby neo » Tue Sep 06, 2005 2:15 pm
I got solid urethane mounts made for the front and rear of my 20v.. Works great, as there is no stupid rocking of the engine after you accelerate then break...
Hey Toyrota How much would u charge per mount as I dunno if the ppl I got to do it will do it again .???
neo
Postby Mr Revhead » Tue Sep 06, 2005 2:21 pm
how much for 4?
i need a full set of aw11 ones 8)
Postby trueno_20v » Sat Nov 19, 2005 11:58 am
While i was putting my new clutch in i finally had a good look at the rear engine mount (the only one i couldnt see) and it looks like its rotted or something so i have replaced it with a new replacement, hopefully this was why my cam belt side engine mount kept breaking.. heres some pics
ADMIN EDIT: signature too large
trueno_20v
Postby neo » Sat Nov 19, 2005 12:45 pm
Mr Revhead wrote:how much for 4?
Im about to get some done, $20 of the crinkly folding stuff each, but you must supply a new mount (well thats all I have done so far to ensure the new urethane gets a good bond)
neo
Postby Mr Revhead » Sat Nov 19, 2005 7:12 pm
as in a brand new mount?
hmmmmm iv seen it done with 2nd hand.. which is all i have...
im in no rush... need other things first....
