4AGE cam talk.
4AGE cam talk.
Postby Jebus » Wed Aug 31, 2005 10:33 pm
Was breifly discussed in another thread but would like to know more.
Mr Revhead says there are two types of camshafts for 16V 4AGE's.
One of them being 240 degree, the other being 232 degree.
Bluetop TVIS = 240
Red Top TVIS = 232
Red Top SmallPort = 232
GZE = 232
Why did toyota give the red top tvis the big port head, and then give it the cam shaft with the lower duration? Doesnt that just seem daft going against the flow characterists and head design, when the blue top seemed fine with the bigger cams, they made the red top TVIS extra crap with smaller cams.
What gain roughly can be had from using the 240 camshafts in a motor that originally had 232 camshafts? Probaly only a few horsies but it all adds up.
And with cam timing settings, does anyone know any that differ from these on Club4ag
For more bottom end power retard the exhaust 4° and advance the intake 3°. For more top end, advance intake 4°and exhaust 3° from stock settings.
Jebus
Postby NA Drifter » Thu Sep 01, 2005 1:27 am
you will also find not only duration is reduced, but also lift.. from like 7.4mm? to 7.1mm .. somthing like that..
It make me wonder for a while too, but I think they did it because of the smallport doesn't have T-VIS and to make it still "driveable", they reduce the cam profile so the car can idle properly, and have good low end town driving capability etc?
Also probably that's why redtop t-vis motor is the worst one out of all?
Keith
NA Drifter
Re: 4AGE cam talk.
Postby ants_ae92 » Thu Sep 01, 2005 12:03 pm
Jebus wrote:Bluetop TVIS = 240
Red Top TVIS = 232
GZE = 232
red top tvis with 232 degrees?
I am pretty sure any big port has 240deg cams?
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1548
Current Ride: ae101 1997 White corolla BZ-touring station
Previous Rides: ae92 Levin (smallport 4age, Lowered, 17s, exhaust, intake). Ke70 Station wagon (4k, lowered)
ants_ae92
Postby CozmoNz » Thu Sep 01, 2005 12:43 pm
if such the case, why do all the ze boys, swap their cams for blue top, and not redtop?
Rayne For President!
CozmoNz
Postby ants_ae92 » Thu Sep 01, 2005 1:29 pm
Then why with the same port size, intake manifld etc, does it make less power but at the same rpm as the blue top?
If every thing is the same except the larger internals, if they used smaller duration shouldnt it make power at a lower rpm?
Possibly also because there are lots of blue tops????
ants_ae92
Postby vvega » Thu Sep 01, 2005 1:34 pm
ants_ae92 wrote:Then why with the same port size, intake manifld etc, does it make less power but at the same rpm as the blue top?
to me this makes no sence ??
v
vvega
Postby Silent Knight » Thu Sep 01, 2005 2:01 pm
v
n00b obviously he said that there's more blue tops so it MUST mean that they make better power at low RPM. :lol:
Silent Knight
Postby Punter » Thu Sep 01, 2005 2:18 pm
Ahhhh power in numbers...... :roll:
I love deadlines. I like the whooshing sound they make as they fly by.
Punter
Postby JamesM » Thu Sep 01, 2005 2:56 pm
lol.. does anyone keep on topic?
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
Postby Jebus » Thu Sep 01, 2005 5:15 pm
hmm, i agree with antz. Im trying to figure out why they would give the red top TVIS the smaller cams, when the head is the exact same as a blue top (which has the larger cams)
Can anyone confirm what Mr Revhead said?
Jebus
Postby crnkin » Thu Sep 01, 2005 5:37 pm
from what i understand what you said in the first post is right
I had a redtop tvis and the cams were defs different to bluetop. BTW anyone got some blue top cams :)
deaf_homo "currrently yes"
crnkin
Postby Jebus » Thu Sep 01, 2005 5:50 pm
I do :D
However are destined for my red top :P
Jebus
Postby ChaosAD » Thu Sep 01, 2005 6:31 pm
ChaosAD
Postby AE85coupe » Thu Sep 01, 2005 7:28 pm
so does anyone know how much gain there is in using bluetop cams in a red top?
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby Bazda » Fri Sep 02, 2005 12:18 pm
I put bluetop cams into my 4agte, very minimal gain but every bit helps.
Postby EVLGTZ » Fri Sep 02, 2005 12:19 pm
Bazda wrote:I put bluetop cams into my 4agte, very minimal gain but every bit helps.
indeed it does, worth doing if ya got the time and a spare set of blueys
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby wanado13's » Fri Sep 02, 2005 1:21 pm
I have a set of blue tops I'm going to put in my ae92 gtz when I do my cambelt in the next couple of months. Although Bazda and evilgtz had no problems with just chuckin them in i've been told by a few people you have to check some things first. If anyone has done this check and knows what you have to measure and what the measurements need to be could they please put them up?
wanado13's
Postby Bazda » Fri Sep 02, 2005 1:24 pm
check ur valve clearances.
cant remember off by hart what they, somewhere around 0.2m-0.3mm
Postby blackie » Fri Sep 02, 2005 4:48 pm
CozmoNz wrote:if such the case, why do all the ze boys, swap their cams for blue top, and not redtop?
... because as stated above, bluetops are 240deg vs 232 for red..
blackie
Postby Jebus » Fri Sep 02, 2005 10:35 pm
Thats exactly what he was getting at :roll:
Jebus
