Help: Cailper Failure AE86 > BANG
Postby beeker » Sat Sep 03, 2005 6:34 pm
I recently had the two rear AE86 callipers professionally rebuilt (unnamed merchant at this stage), and fitted them myself.
I bleed the rears and had got to the last front wheel when BANG, what the!! Went to the back of the car, and there was brake fluid splatter everywhere and on the wall too. On inspection, the caliper piston rubber grommet has a 2mm hole in it. I assume the seal below it gave way.
Could I have caused this ??
> Could I have been bleeding them incorrectly ?
> The new pads were extra thick, and I had to twist the callipers all the way in to slide the calliper over the rotor.
Any ideas ?
Faulty parts ? Incorrect rebuild of the calliper ?
Note: I hadn't even started the engine, and got the brake booster started yet. Also installed some braided lines at the same time... Not enough give in the system with meaty pads ??
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby evil_si » Sun Sep 04, 2005 9:39 am
probably been pinched on assembly, and when almost up to full pressure has given way
evil_si
Postby vvega » Sun Sep 04, 2005 10:20 am
yeah sounds like that or they didnt use rubber grease and when you twisted it its pinched and grapped on the bore wall
v
vvega
Postby NZ_AE86 » Sun Sep 04, 2005 5:54 pm
IMO this could only happen if they were poorly rebuilt. 8O
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
