AE82 Bouncing Revs.
AE82 Bouncing Revs.
Postby Kermit12a » Mon Sep 05, 2005 3:32 pm
Can anyone help?
I have a FXGT (Fun car) with only thing done to it is the air filter has been changed to a K&N. There are 2 solenoids that are not connected to any thing that from what I can tell one was attached to the original air box and the other is against the firewall on the passenger’s side.
My car revs funny. When it is cold it is fine but as it warms up and sits at 800rpm or so it will bounce between this and 1100rpm. :? :evil:
Does anyone else have this prob or have any ideas how to fix it???
[/b]
AE82 FXGT all the way
Go the Old School
Kermit12a
Postby pervert » Mon Sep 05, 2005 3:33 pm
Idle stepper motor's packed a sad maybe?
pervert
Postby Kermit12a » Mon Sep 05, 2005 3:38 pm
Ok so where do I find that??
Go the Old School
Kermit12a
Postby pervert » Mon Sep 05, 2005 3:40 pm
Under the bonnet.
pervert
Postby Kermit12a » Mon Sep 05, 2005 3:41 pm
Thats where most of the past for the motor are kept.
Ok will I will consoult the manual for that one.
Thanks
Go the Old School
Kermit12a
Postby mr pad » Mon Sep 05, 2005 3:51 pm
pervert wrote:Under the bonnet.
Now thats tech help :lol:
mr pad
Postby pervert » Mon Sep 05, 2005 4:01 pm
A+ dude, A+... :lol:
pervert
Postby GTCRSHR » Mon Sep 05, 2005 5:49 pm
on my old one it was a vaccume leak from the pipe that goes to the filter nothing a bit of duct tape didnt sort out (was a piece of crap anyway)
Nothing to see here ...
GTCRSHR
Postby Mr Revhead » Mon Sep 05, 2005 6:38 pm
these engines dont have an idle stepper motor.
they use a wax pellet type idle control valve bolted to the underside of the throttle body. cannot repair that im afraid
Postby 85AW20v » Mon Sep 05, 2005 6:45 pm
But you can pull it off and clean all the crap out of it. Worked for me when I had the bluetop in the MR2.
See ya
Simon
85 MR2 20v
85AW20v
Postby Mr Revhead » Mon Sep 05, 2005 6:49 pm
well yes, if thats the problem. they do fail internally.
so pull it off and have a play. so to speak......
Postby thaphatty » Mon Sep 05, 2005 7:23 pm
sounds like a vaccum leak to me
thaphatty
Postby nobody » Tue Sep 06, 2005 11:26 am
Just something super simple to check first: make sure you air con is off :) With my ae82 it used to drop quite a few hundred revs when the air con kicked in - not as noticable at higher revs when cold.
Otherwise - what the others said.
nobody
Postby Kermit12a » Tue Sep 06, 2005 11:29 am
My air con does not work the fan fuse thingie (memory laps) keeps popping. I have to take the kick panle off the passanger side remove it and reset it. then it works for a while then it stops. :x
I had my mecanic look at it and he just cleaned the air intake and adjusted the rebe level. this fixed for a little while.
Go the Old School
Kermit12a
