silvertop 20v into ae92
Postby deaf_rattle » Mon Sep 05, 2005 8:01 pm
i have been doing my research, and from what i can gather
use the ae92 4age engine mounts
my manual gearbox will bolt up (use my fly wheel and clutch as well)
i will need to sort out the coolant lines, but not if i put in a ae101 radiator as well.
the throttle cable will swap straight over as long as i use the ae101 pedal.
i will need to get the exhaust modified
then there is the wiring.
Will the ae92 power steering pump bolt up?
Will the stock starter motor work with the silvertop even tho it will be mounted on the opposite side? (using ae92 flywheel etc) ?
Postby 85AW20v » Mon Sep 05, 2005 10:15 pm
One question I can answer. As the starter motor is bolting up to your original gearbox, it will work. The 20V starter motor is a different bolt pattern.
See ya
Simon
85 MR2 20v
85AW20v
Postby deaf_rattle » Mon Sep 05, 2005 10:53 pm
sweet, thanks for your help.
I might do a step by step thingo with pictures, so others wont have to ask annoying questions like me
Postby Lloyd » Mon Sep 05, 2005 11:42 pm
An AE101 rediator in my AE92 sat a little too high for the bonnet to close completely so you might have to shorten the mounts on the bottom a little. Its little things like that that piss you off :P
Postby Distrb » Tue Sep 06, 2005 10:45 am
the ae92 power steering pump should bolt up... you might need to modify the bracket a little so it sits right... but that wont take much....
see if you can source a silvertop power steering pump bracket so you can mix and match if needs be..
Distrb
Regular Poster
Postby ae82gt » Thu Sep 08, 2005 8:43 pm
ive done this in a ae82, piece of cake only hick up was lower coolant hose and the trottle cable was abit short apart from that some
little wiring things
ae82gt
Postby ae82gt » Thu Sep 08, 2005 8:44 pm
ae82gt
Postby deaf_rattle » Thu Sep 08, 2005 10:27 pm
true, any tips with the wiring?
and did you need certification?
Postby spencer » Thu Sep 08, 2005 11:14 pm
wiring can seem like a big task but once you get the pin out diagrams for both engines you'll be away. Theres not that many wires to actually get it running theres alot of crap and if you have any specific problems just ask on here
spencer
Postby deaf_rattle » Fri Sep 09, 2005 7:39 am
sweet as
yeah i might get extra keen and make some wiring adaptors so i can put a red top straight back in if need be.
but yeah once i get the motor im sure ill be annoying the board with more annoying questions
Postby ae82gt » Thu Sep 29, 2005 8:03 pm
deaf_rattle wrote:true, any tips with the wiring?
wiring was a bit of a hassle take the top of your red top computor to get the right pin out,all the ones i found on the net werent the same as mine , i couldnt get my 20v computer to trip my fuel pump so had to rewire that thats about it .
didnt get it certed my wof man happy to give it a wof keep the old vin plate off the 101 in the glove box tho its still a 4age 1587 cc just goes a bit better :lol:
fxgt ae82 20v
fxgt ae101
ae82gt
Postby 85AW20v » Thu Sep 29, 2005 11:10 pm
The fuel pump problem is more to do with the circuit open relay and starter relay than trying to get the computer to do it. You also need to connect a wire from the AFM plug that goes to earth when the flap is open - white with black trace from memory. With the key on, push open the AFM flap and the fuel pump should run.
See ya
Simon
85 MR2 20v
85AW20v
Postby AE86less » Sun Feb 11, 2007 6:18 pm
*Dredges up ancient topic with aid of search function*
I'm looking at possibly sticking a silvertop in a ae9(/8 )2 with either the original gearbox or a 6 speed item. What is required there?
What are the mounts like in the 1300 version? Will i need new mounts?
I dont think the silvertop came with a 6 speed did it? I assume that the blacktop gbox bolts right up? What are the differences (if any) in the mounts for the standard and 6speed? (Dont know the codes)
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby slighty_sykotic » Sun Feb 11, 2007 6:46 pm
Left hand gearbox mount on a 6speed is different from the 5 speed verisons. Can be modified to fit though pretty easily.
The gearbox itself will bolt to the silvertop.
1300 mounts would be different, as it wont be a a series motor. (I beleive). Get a 4afe/ge powered one to start with, much easier.
--Sykotic
slighty_sykotic
Postby AE86less » Sun Feb 11, 2007 7:45 pm
Alright, cheers for that.
One more question: Would that require Certing?
And off topic: What sort of engine is actually in the 1300 ones?
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby Dell'Orto » Sun Feb 11, 2007 8:29 pm
Yes, it will require certing. If its a 1300 it'll be an EE80/90, with a 2E of d00m.
Postby AE86less » Mon Feb 12, 2007 8:09 pm
How different are the 1300 mounts? Could i just get a set of fwd 4age mounts and chuck them in? And would the price on that make buying this worth while?
http://www.trademe.co.nz/Browse/Listing.aspx?id=87139714
Thats assuming it's got a good body.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby Zak » Mon Feb 12, 2007 9:36 pm
You have to unstitch the drivers side mount and get the 4age one welded on, it's not really worth the hassle
Zak
Postby AE86less » Wed Feb 14, 2007 4:20 pm
Whats the code of the six speed box?
This plan is almost definate now so i gotta get sorted.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby AE86less » Thu Feb 15, 2007 7:11 pm
Answer anywhere? I need to do some proper research so i can do some decent budgeting, but i can't find that code anywhere to ask wreckers or search websites etc.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
