4age computer in diagnostics mode?
Postby ants_ae92 » Fri Sep 09, 2005 1:00 pm
Just wondering what exactly would a 4age tvis computer do when it is running in diagnostics mode? I mean would it cut timing? run it only in closed or open loop?
Just interested as it could be an option for me running a tvis motor with a td04 or other small turbo?
I can find the diagnostics box on my ae92 levin, but don't know how to do it, how do you run it in diagnostics mode?
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1548
Current Ride: ae101 1997 White corolla BZ-touring station
Previous Rides: ae92 Levin (smallport 4age, Lowered, 17s, exhaust, intake). Ke70 Station wagon (4k, lowered)
ants_ae92
Postby Ae92typeX » Fri Sep 09, 2005 1:22 pm
Im not 100% sure, but I thought all it did was aleart you/ help you read any malfunctions in the system. No idea if it changes any of the running operation.none of my written material suggests either way.
Really, for running a turbo, if you dont go gze ecu or aftermarket (both a better option) you would want to manually alter the timing and get more fuel by other means than say putting an ecu into a check mode.
to put in diagnosis, off the top of my head bridge te1 e1
Ae92typeX
Postby ants_ae92 » Fri Sep 09, 2005 3:08 pm
Yeah I have considered going gze ecu as well.
Does anyone else know what the ecu will do in diagnostics mode?
ants_ae92
Postby crnkin » Sat Sep 10, 2005 12:40 am
it will ignore most of the sensors and just run even tho its bout to blow :P
deaf_homo "currrently yes"
crnkin
