264 cams in 4age
264 cams in 4age
Postby trdnut » Mon Sep 12, 2005 12:30 pm
Wanted to know what needs to done to put 264 degree cams in a 4age smallport?
Anyone know here i could have my cams ground in aucks?
Pleeez
trdnut
Postby ants_ae92 » Mon Sep 12, 2005 12:57 pm
Franklin cams?
May need to measure clearances in the shims and/or reshim
Good cam choice as well
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1548
Current Ride: ae101 1997 White corolla BZ-touring station
Previous Rides: ae92 Levin (smallport 4age, Lowered, 17s, exhaust, intake). Ke70 Station wagon (4k, lowered)
ants_ae92
Postby Peradx » Mon Sep 12, 2005 10:48 pm
I'm running HKS 256 degree cams in my smallport with no other mods to the valve train. with the HKS ones you can go up to 272 degrees without doing anything to the valve train.
If you're going to use regrounded cams I'd find out what the lift is once they have been reground. then find someone who knows what they are talking about, to find out what if anything else will be needed to be done to your valve train.
Peradx
Postby trdnut » Tue Sep 13, 2005 12:01 am
Sounds good, want to have them ground to 8.3 mm lift (same as hks 264's)
trdnut
trdnut
Postby trdnut » Tue Sep 13, 2005 12:06 am
how does it go with the 256's anyhow? Big gains i'm assuming?
trdnut
Postby pc » Tue Sep 13, 2005 12:14 am
My reground cams (from Kelford) in my bluetop are 222 degrees at 0.50" lift, and 0.327" cam lift... which I think is about the specs you are looking at.
The only thing that is new is some little caps to put on the top of the valve stems (Kelford supplied these) that make up for the ground/reduced base circle on the cams.
Very simple, no computer/injector/etc. changes needed.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Users browsing this forum: Bing [Bot] and 8 guests
