Tie rod end part 2.
Tie rod end part 2.
Postby pervert » Mon Sep 12, 2005 6:35 pm
Haha, well I'm a dick...
Got the tie rod end seperated from the steering arm knuckle tonight, undid the nut a few turns, few sharp smacks to the side of the steering arm knuckle, and it popped free...
Now, the nut is still most of the way on the end of the shaft, but when I try to undo it it just turns the whole shaft...so although its free, I now can't get the nut off...
What have I $&#$% up now... :lol:
pervert
Postby trueno_20v » Mon Sep 12, 2005 6:43 pm
hey i think there will be a alan key you can put in the center on the shaft and hold it while turning the nut with a spanner :wink:
ADMIN EDIT: signature too large
trueno_20v
Postby TrouserFxGt » Mon Sep 12, 2005 6:44 pm
Its just rotating in the bearing cup, nothing to worry about. Tap the whole lot back into the hole, remove the nut and tap it out again.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby pervert » Mon Sep 12, 2005 6:53 pm
TrouserFxGt wrote:Its just rotating in the bearing cup, nothing to worry about. Tap the whole lot back into the hole, remove the nut and tap it out again.
Tried that, it just won't $&#$% stay still... :lol:
I've got the nut half off, but it just won't come anymore...
pervert
Postby trueno_20v » Mon Sep 12, 2005 7:00 pm
can you put an alan key in the center of sharft?
trueno_20v
Postby pervert » Mon Sep 12, 2005 7:13 pm
trueno_20v wrote:can you put an alan key in the center of sharft?
No.
pervert
Postby AE85coupe » Mon Sep 12, 2005 7:56 pm
this is gonna sound rugged, but get some vice grips and hold the bottom of it, then turn
kinda rough but works if you have enough room
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby pervert » Mon Sep 12, 2005 8:08 pm
AE85coupe wrote:this is gonna sound rugged, but get some vice grips and hold the bottom of it, then turn
Yup, think that's what it's going to come to... :lol:
Got dark so I gave it the big finger tonight, but I might just cut the $&#$% off with the grinder tommorrow, I'll just take the tie rod off my parts car if I $&#$% the thread... 8)
pervert
Postby fangsport » Mon Sep 12, 2005 8:16 pm
did we, by chance root the end of the thread when trying to remove ball joint with hammer??
fangsport
Postby pervert » Mon Sep 12, 2005 8:26 pm
fangsport wrote:did we, by chance root the end of the thread when trying to remove ball joint with hammer??
Yes, by chance we did... :lol: :lol: :lol: :lol:
I kinda guessed that was the issue a few hours ago, about when I thought it's too dark to go getting the grinder out... 8)
pervert
Postby 85AW20v » Mon Sep 12, 2005 11:10 pm
You can also use your jack under it and get a heap more upward pressure on it. Keep lifting until all the supension movement is taken up and you start to lift the car. Should be enough to jam it in the taper again.
See ya
Simon
85 MR2 20v
85AW20v
Postby pervert » Mon Sep 12, 2005 11:36 pm
Simon85MR220v wrote:You can also use your jack under it and get a heap more upward pressure on it. Keep lifting until all the supension movement is taken up and you start to lift the car. Should be enough to jam it in the taper again.
Did that, that's how I got it from fully on, to half off... 8)
pervert
Postby Lloyd » Mon Sep 12, 2005 11:38 pm
Time to amputate it :P
So little faith in the "bash the crap out of the side of it" method. One day young grasshopper, you will learn.
Postby fangsport » Mon Sep 12, 2005 11:52 pm
if you do amputate it, doing the following will save you from needing a wheel alignment:
get a paint pen and a black marker and accurately mark the locknut or tie-rod end. loosen the locknut 1/2 a turn, and remove tie-rod end. if the replacement is exactly the same, your wheel alignment will be the same as before you removed it.
fangsport
Postby scope » Tue Sep 13, 2005 12:15 am
wanna buy my plate pervert? 8)
chicken fillet and bacon with everything except onion and bbq, ranch and southwest sauces
current ride: 1980 mazda rx7 series 1
previous rides: ke36 corolla, series 1 rx7, ke30 corolla, ke70 corolla x2
scope
Postby Ae92typeX » Tue Sep 13, 2005 1:42 am
could be worth looking at replacing it anyway, being loose suggests its halfway through its life and if you ever need to take it off again it will be even harder (assuming it tightens up ok again anyway)
pretty cheap part new.
Ae92typeX
