Boost Gauge and 4AGZE
Postby beeker » Sun Sep 18, 2005 9:46 pm
I've got an Autometer 20psi boost gauge in the 4AGZE. Problem is, at no throttle it reads approx -4psi, and at full throttle approx +4psi. The previous spitfire did approx the same.
Have i hooked it up wrong, or is this normal for a 4AGZE ?
thx in advance.
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby evil_si » Sun Sep 18, 2005 10:18 pm
you have no doubt connected it wrong.
were have yoy t'd it into?
there is a little fitting out the top of the inlet manifold, i can remeber what it feeds but its the one you want to use i will try and find a link with a picture
evil_si
Postby beeker » Sun Sep 18, 2005 10:31 pm
This is where its currently hooked up.
06 RS4 Avant
beeker
Postby Rick » Sun Sep 18, 2005 10:35 pm
dont you tee into the vacuum line that goes from the intake manifold to the brown vacuum valve which operates the fuel pressre regulator?
Postby pidge » Sun Sep 18, 2005 10:41 pm
It looks like you've hooked it up to the vaccum line that goies to the FPR, not the line that comes from the inlet manifold. I think the one you want to tap into is the one running in front off the otehr two vaccum lines in the picture, going by a comparision with my "before" picture of a AE101 VSV bypass:
(I'd rotate the picture so it corresponds to your's, but I can't be arsed.)
pidge
Postby beeker » Tue Sep 20, 2005 8:31 pm
pidge wrote:It looks like you've hooked it up to the vaccum line that goies to the FPR, not the line that comes from the inlet manifold. I think the one you want to tap into is the one running in front off the otehr two vaccum lines in the picture, going by a comparision with my "before" picture of a AE101 VSV bypass:
Any chance of a pic of where "the line that comes from the inlet manifold" hits the manifold ?
From looking at my car, the other two options either go to the ~wategate or the supercharger.
06 RS4 Avant
beeker
Postby bluemaumau » Thu May 04, 2006 9:04 pm
old post, just wondering if someone can provide the correct answer?
which line to "t"?
Postby sk1dlet » Thu May 04, 2006 9:21 pm
T into the line that comes from the inlet manifold
82 4DR KP62 4AGTE MADNESS
98 RS200 ALTEZZA
sk1dlet
Postby bluemaumau » Thu May 04, 2006 9:36 pm
the big fat one in that pic? (with the pink writing on it)
Postby sk1dlet » Thu May 04, 2006 9:51 pm
no the one that comes from the inlet manifold bolted to the block, not the ones from throttle body or anywhere else
98 RS200 ALTEZZA
sk1dlet
Postby bluemaumau » Thu May 04, 2006 10:25 pm
yea i get what a inlet is dude. :lol:
where does this line run to. sorry its raining, and me engines in the barn. 8)
Postby beeker » Thu May 04, 2006 10:46 pm
My problem was finally resolved with decent OEM vacum tubing. The crap stuff i got from supercheap caused the whole problem !!
06 RS4 Avant
beeker
Postby bluemaumau » Thu May 04, 2006 10:50 pm
jeez do you need good piping to?! 8O
is OEM like a standard of piping?
i was just gonna go to hammer hardwear. :lol:
so you did have it in the correct place?
Postby bluemaumau » Thu May 04, 2006 10:51 pm
surely the piping dosent matter, esp if you clamp each end?
but yea was your "T" in the right place?
Postby 2LTR Rona » Thu May 04, 2006 11:23 pm
It will matter especially if its low quality that allows the pressurized air to escape while traveling through the line, this will result in a lower and false reading on the gauge, bit like a hose with pins holes in it :wink:
2002 Altezza, 1974 KE25
2LTR Rona
Postby bluemaumau » Fri May 05, 2006 12:00 am
ok so were does everyone go to get good boost gauge piping???
Postby beeker » Fri May 05, 2006 7:17 am
bluemaumau wrote:ok so were does everyone go to get good boost gauge piping???
I got some OEM Toyota Vacum piping. Visit a wrecker or in my case i ordered some from toyota as i had limited time.
06 RS4 Avant
beeker
Postby aesc » Fri May 05, 2006 10:08 am
Repco has Gates vac line, pretty decent stuff. I haven't had any problems with Super Cheap vac line so far either
EX AE101 owner
2013 Ford Focus ST
aesc
Postby bluemaumau » Fri May 05, 2006 10:58 am
ok cheers guys.
jeez i thort a pipe was a pipe. 8O
Postby crnkin » Fri May 05, 2006 4:27 pm
out of interst, i have this shitey vac tube, and in every guage ive had, (2) the needle always shakes at full bost, varying by about 2 psi, like a really rapid shake, so i can never tell if its actually 5psi or 7psi (so i say 6).
Would a better hose in theory fix this? anyone had the same problem?
deaf_homo "currrently yes"
crnkin
