gtz turbo inlet temp sensor Q?
Postby B-style » Mon Sep 19, 2005 12:12 am
i have an ae101 gtz turbo running standard computer. i was running a td04l off a gsr and on really hot days it'll run extremely shit!
now from standard the ae101 gtz's (airflow meter dont, only map) run an inlet manifold temp sensor, this retards ignition when the 'supercharger/air' gets to hot to stop damage against the engine. i know that some people out there just don't connect it when converting to turbo, my car was converted by speedtech and believe it was there first setup they've done (with standard comp) and they adapted it to the standard ae92 small port manifold.
my question is, can i disconnect it? it'll make my car a lot faster at masterton thats for sure! (got to 32degrees last time!)
thanks heaps brent
1997 honda integra type r
1992 toyota levin gt-z turbo
B-style
Postby Akane » Mon Sep 19, 2005 1:16 am
Don't be stupid, it's there for a reason. Get a bigger intercooler.
Re: gtz turbo inlet temp sensor Q?
Postby CozmoNz » Mon Sep 19, 2005 1:28 am
B-style wrote:can i disconnect it? it'll make my car a lot faster at masterton thats for sure! (got to 32degrees last time!)
thanks heaps brent
You can...
however any damage done, is not the fault of toyspeed.org.nz or any information you were given from here :P
in short, NONO!
Rayne For President!
CozmoNz
Postby Bazda » Mon Sep 19, 2005 11:13 am
Turbo is to small thats your problem, its the size of a dunkin donut. :D
Oh and 32 degrees is a very good operating temp.
Postby gtcielo » Thu Sep 22, 2005 5:49 pm
Bazda wrote:Turbo is to small thats your problem, its the size of a dunkin donut. :D
haha
gtcielo
