Drifter4ag wrote:my standard bluetop made 176kw@wheels with HT182s combination turbo and 9.2:1 compression ratio on just over 14psi .. so im guessing that with the turbo rebuilt and and engine that can handle it you should be able to hit 220kw with that turbo on about 20psi ... with some cams etc .. the engine i have in the build will be around the 220kw@wheels figure so see how we go.
Mr Revhead wrote:yeah i know of a fairly good 20v turbo making around 3-330 at the fly on around 20ish psi.... quite low compression though.
what cams you using?
CAMB01 wrote:What wud i need to do to get 300hp atw.
I'm currently building up a 4AGTE for high hp.
crnkin wrote:Mr Revhead wrote:yeah i know of a fairly good 20v turbo making around 3-330 at the fly on around 20ish psi.... quite low compression though.
thats with a tiny t25 and low comp too
Bazda wrote:hmm i aint touching the head on mine, but i wouldnt think I would get any more than 400hp....thats running with an autronic and be tuned on Lynn rodgers engine dyno.
what hp does the speedtech dx run?
