4agt/ze Engine balancing and building?
Postby crnkin » Tue Sep 20, 2005 12:13 am
Hey guys, finally aquired my super setup, wicked rods, high comp 4agze pistons, retopblock with squirters, smallport head, and external ancillaries.
What i want to know now is who in what area has had their engine balanced and/or built buy who, for how much, and what their reccomendations are?
The engine only needs minor balancing, ie crank+flywheel lightened, de burred and balanced, rod and piston assembly deburred and balanced, anything else?
Then i want the head p+p'd with larger valves maybe and flowed/tested to 1600cc specs.
Glenn dont know it yet but i was gonna ask him to help, but before i do im gonna do my research first.
The engines goal is 250kw atw MINIMUM with 275 kw atw being ultimate goal. As far as i can gather this is around about 350hp atw and around 400-450 at the fly.
The boost pressure will be somewhere between 20-25psi max, i assume 22psi will bring my goal as 24psi on low comp is about 350hp atw.
Ive been trying to read flow maps etc, and from what i gather about 22-23 psi is the most efficient range for a skyline t3 and rx7 HT18s hybrid, so that should be the turbo used, and injectors flowing 440cc may not be quite enough, so perhaps 550cc rx7 injectors?
Please shed some light oh toyspeed gods, thanks!
deaf_homo "currrently yes"
crnkin
Postby CAMB01 » Tue Sep 20, 2005 8:28 am
Have a talk to Kerry at Kerry Lindsay Engine Reconditioners.
I have to say that coz i work there.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Bazda » Tue Sep 20, 2005 1:48 pm
thats alot of horse power for that smallish turbo...
The guys in aussie only making that with huge turbonetic t3/4s running 25psi+ and 20v heads.
That is kinda my goal power range and im 1800cc 8O using a turbo with a 83mm comp wheel and a 72mm exhaust wheel...
If u can get that hp i wonder what im going to get then...... :roll:
I dont think you woudl need to get it balanced, the rods if aftermarket forged ones shoudl eb balanced when they make them, and toyota pistons will also be balanced from factory.
maybe if u had a crank grind or something then you woudl need to balance the crank, unless ur running a different fly wheel..
Postby RomanV » Tue Sep 20, 2005 2:06 pm
Yeah, thats seems like a lot to ask from a 1600cc engine. :?
To get 225kw at the wheels, you're gonna have to make at least 375hp at the flywheel.
Which is quite a lot. 8O
Postby Mr Revhead » Tue Sep 20, 2005 2:14 pm
yeah i know of a fairly good 20v turbo making around 3-330 at the fly on around 20ish psi.... quite low compression though.
what cams you using?
Postby Bazda » Tue Sep 20, 2005 2:48 pm
My last car we figured was making 300hp+ with the standard ecu, as my old mans escort was making 285hp at that time and with a 100kg lighter car. We were very similar in a straight line I had a bit more puff up high having such a big turbo :D, but he had more torque down low.
Maybe if u put cams/vlave springs enough to rev it to 9000rpm and a lynn rodgers $2000 head job + a turbo bigger than a t3/4 you could be looking at 400hp+
Postby Drifter4ag » Tue Sep 20, 2005 5:49 pm
my standard bluetop made 176kw@wheels with HT182s combination turbo and 9.2:1 compression ratio on just over 14psi .. so im guessing that with the turbo rebuilt and and engine that can handle it you should be able to hit 220kw with that turbo on about 20psi ... with some cams etc .. the engine i have in the build will be around the 220kw@wheels figure so see how we go.
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby CAMB01 » Tue Sep 20, 2005 6:07 pm
What wud i need to do to get 300hp atw.
I'm currently building up a 4AGTE for high hp.
CAMB01
Postby AE86fan » Tue Sep 20, 2005 9:24 pm
Im just finishing a build to simular specs but with a RNN14 T28. I found the gze pistons all weighed exactly the same to .5gms which is bloody good from factory. With a good set of scales and a bit of time its not that difficult to get pistons and rods weighing all the same.
1984 NZ AE86
AE86fan
Postby crnkin » Tue Sep 20, 2005 10:45 pm
Drifter4ag wrote:my standard bluetop made 176kw@wheels with HT182s combination turbo and 9.2:1 compression ratio on just over 14psi .. so im guessing that with the turbo rebuilt and and engine that can handle it you should be able to hit 220kw with that turbo on about 20psi ... with some cams etc .. the engine i have in the build will be around the 220kw@wheels figure so see how we go.
Exactly matt. Big turbo does not equal big power, 5 valves per cylinder doesnt equal big power, low comp DEFNITELY does not equal big power.
CAM01 whats your name? and where is this engine recon place?
as for balancing, the closer to balanced the better, and the rods will need to be de burred, secret spec hehe NOT. And the pistons together with rods if each .5g out each way equals a 2g difference, ie too much.
I know of a stock ht18s on a 4agze running 240kw atw, on low comp, its already been done, and im running high comp= high power
ummmmmm where next... roman v- 450 flywheel is the aim
mr revhead- thats what im asking! what cams?
and last but not least, bazda, for a 2g headjob id expect new everything, and the whole head would be a valve! :) (they can flow about 800hp on a 7agte)
Turbo wise- i already know the t3/4 will flow over 550 hp at 25+ psi on a 1800 with medium comp.
So thanks all you guys for the comments, yes it will work, yes that power is acheivable, but can anyone answer the questions?
(comments are cool too but dont doubt it :) )
crnkin
Postby crnkin » Tue Sep 20, 2005 10:46 pm
Mr Revhead wrote:yeah i know of a fairly good 20v turbo making around 3-330 at the fly on around 20ish psi.... quite low compression though.
thats with a tiny t25 and low comp too
crnkin
Postby crnkin » Tue Sep 20, 2005 11:12 pm
CAMB01 wrote:What wud i need to do to get 300hp atw.
bluetop, t3/4, vr4 intercooler, gtr injectors, link computer. thats all. 300hp is sweet- ask matt or any garage dori boys
crnkin
Postby Bazda » Tue Sep 20, 2005 11:40 pm
hmm i aint touching the head on mine, but i wouldnt think I would get any more than 400hp....thats running with an autronic and be tuned on Lynn rodgers engine dyno.
what hp does the speedtech dx run?
Postby matt dunn » Wed Sep 21, 2005 12:06 am
T28 I think, and the silvia one not the GTiR.
Postby IH8TEC » Wed Sep 21, 2005 8:07 am
Bazda wrote:hmm i aint touching the head on mine, but i wouldnt think I would get any more than 400hp....thats running with an autronic and be tuned on Lynn rodgers engine dyno.
500ish hp
Postby Drifter4ag » Wed Sep 21, 2005 9:27 am
nzpc at one stage said that speedtech thing was pushing like 550+ on andres dyno ... .. dunno if that has any cam shafts or anything but running a GT40 turbo or what ever it was then i would expect some big numbers from big boost.
But if you going for balance.. then i would hit lyn rogers up hes the man
440s will be dying out over about 190w@wheels .. so i would def start with 550s if you can get them
i would be inclined to go with a big port head :D but im nuts ...
not sure what limits are for flow on stock intake manifold but
dudes in the states are still using them with close to 400hp
balance from lyn if everything is cleaned and ready is about 300$ but you may as well get him to assemble the whole bottom end
or it might be $500 .. i cant remember .. i think its 500
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby crnkin » Wed Sep 21, 2005 11:29 am
Thanks heaps matt, you have his contact details?
crnkin
Postby Bazda » Wed Sep 21, 2005 11:35 am
114 Vincent St Howick Auckland 09 5343363
You should put your engine on his dyno when your done, nice accurate reading and a very nice piece of machinery it is!!!!
Takes only an hour to tune an engine using autronic!
Postby Mr Revhead » Wed Sep 21, 2005 11:39 am
if i was you id call him asap, hes pretty busy at the moment so maybe booked up for a while
Postby Bazda » Wed Sep 21, 2005 11:43 am
he is booked for months :P
