cant diagnose fault on a vitz
Postby Psycho_Dad » Thu Sep 22, 2005 1:41 pm
hey guys, i am currently troubleshooting a 2000 toyota vitz(echo import) powered by a 1sz-fe... it has a intermittant engine light and radiator light problem(theirs 2 radiator lights; ones red, ones blue, and blue one is the one causing me hassle) - so i go to do a diagnostic, and theirs no diagnostic plug so i cant bridge the pins... WTF? it happens when driving it around, someitmes cold, sometiemes warm..
so does anyone know what the blue radiator light means? the vitz has enough oil/transfluid/radiator fluid... and if i cant do a diagnostic, whats next?
thanks in advance guys
Psycho_Dad
Psycho_Dad
Postby Mr Revhead » Thu Sep 22, 2005 2:29 pm
the vitz would use the next generation ECUs, there will be a connector in the loom, maybe on the drivers side under the dash.
im not sure if you can bridge the terminals to get the codes though.
the blue one just means its cold. notice how they dont have a temp gauge? :wink:
if its on when its definitly hot, then id be checking ya temp sensors
Re: cant diagnose fault on a vitz
Postby matt dunn » Thu Sep 22, 2005 11:41 pm
Psycho_Dad wrote:hey guys, i am currently troubleshooting a 2000 toyota vitz(echo import) powered by a 1sz-fe... it has a intermittant engine light and radiator light problem(theirs 2 radiator lights; ones red, ones blue, and blue one is the one causing me hassle) - so i go to do a diagnostic, and theirs no diagnostic plug so i cant bridge the pins... WTF? it happens when driving it around, someitmes cold, sometiemes warm..
Psycho_Dad
As said they have no gauge,
just a blue light for cold,
and a red light for too hot,
and nothing for OK.
It will have a diagnosis connector but it will be ODBII shape and you will probably need a scan tool to read and understand the codes out of it.
Check the engine temp after a drive of about 10 mins and see if it's too hot, or too cold, and check the thermostat.
matt
Postby Rob » Fri Sep 23, 2005 10:41 am
Hey man if your on the the shore, take it to wairau auto electrical. They got a mean scanner and thats who we (Dodsons)
Bloody good
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby $CENSLS1$ » Fri Sep 23, 2005 11:00 am
check the thermostat, and all the sensors you can find.
TeamPoon~Building Sex on wheels since '06
$CENSLS1$
Postby Psycho_Dad » Fri Sep 23, 2005 12:52 pm
thanks guys, ill be checking her over today, hopeufully it will just be a sensor
peace
Psycho_Dad
Psycho_Dad
