A question about alloy wheel~~~
Postby cyrus_cynos » Fri Sep 23, 2005 8:41 pm
i`ve got a set of 14 " alloy wheel.
and want to get 4 tyres.
but i dont know what tyres should i choose,eg 185/65 r14 etc
info about the alloy wheels:
4*100,114 multi fit
ET 35
6 J * 14 H2
cyrus_cynos
Postby cyrus_cynos » Fri Sep 23, 2005 8:56 pm
anyone can help?
thx
cyrus_cynos
Postby pidge » Fri Sep 23, 2005 10:29 pm
Get the stock tyre size for your car and go to:
http://www.miata.net/garage/tirecalc.html
Select the stock size and have a play with the new size to find something that matches.
I think your stock size is 175/65R14, so if you wanted to go wider (which you would almst need to on 6" wide rims), you could use 185/60R14 (speed reads 0.9% fast), 195/60R14 (speedo reads 1.1% slow), or 205/55R14 (if you can find that size!) (speed reads 0.3% fast).
Note that you need to make sure that the rim hub is supported by the wheel hub, not by the studs i.e. the wheel hub should centre the rim onto the hub, and that your centreline offset is correct, otherwise you will cause uneven wear on the wheel bearings.
pidge
Postby CozmoNz » Fri Sep 23, 2005 10:37 pm
pidge wrote:I think your stock size is 175/65R14
He has a cynos B (say GT / GT APEX of the levin's / trueno's), Which, in turn, had optional alloy wheels. (good ol toyota)
Gf had 195 / 50? (i think) R15, however could have come factory with 185's.
But no... not 175's its not a starlet :P
Rayne For President!
CozmoNz
Postby cyrus_cynos » Fri Sep 23, 2005 11:59 pm
ok, so i can choose any r14 tyres? only will afeect the speed?
cyrus_cynos
Postby pidge » Sat Sep 24, 2005 8:27 am
Ah. I was looking at the specs for a Cynos Alpha. :?
pidge
Postby Leon » Sat Sep 24, 2005 12:29 pm
cyrus_cynos wrote:ok, so i can choose any r14 tyres? only will afeect the speed?
Cunning plan would be, to look inside the door frame of your car. On the majority of cars, you will find a tag that will tell you the recomended tire pressures, and the standard size tires to suit your car :) If no 14" (only 13") size is listed for your car, ring a tire shop, and ask them which 14" size is the same as the 13" size that you will find on the sticker. That'll get you the exact size tire easy.
Postby Mr Revhead » Sat Sep 24, 2005 12:39 pm
i bet 185/60/14 is the size you need 8)
