reverse lights
reverse lights
Postby GTCRSHR » Mon Sep 26, 2005 9:52 am
hey
my gf car is a kpxx starlet
and her reverse lights arent working i dont really want to mess around to much i have checked the bulbs there fine and the contacts are all clean
what should i start looking at next
Nothing to see here ...
GTCRSHR
Postby GT4 20 » Mon Sep 26, 2005 10:05 am
Check the reverse light switch on the gearbox.
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby GTCRSHR » Mon Sep 26, 2005 10:10 am
would that under the carpet or connected underneath the car (on the g/box) its self
GTCRSHR
Postby GT4 20 » Mon Sep 26, 2005 10:55 am
I don't know the Starlet at all but would guess that the swtich is on the box itself. Perhaps somone else can confirm?
gary
GT4 20
Postby wde_bdy » Mon Sep 26, 2005 11:20 am
On a KP they join the loom just below the coil (same area as dissy/temp/oil wires), then go down to the switch on passengers side of gearbox. Easiest way to test is unplug loom, bridge reversing switch wires and see if the lights come on. If they do then switch or wiring to switch is the problem, if not its something else. Need ignition on for this test.
Callum
wde_bdy
Postby GTCRSHR » Mon Sep 26, 2005 11:23 am
cheers for that will test it tonight
GTCRSHR
Postby GTCRSHR » Thu Sep 29, 2005 8:27 pm
Traced it back to the gear box and unplugged the plugs and pluged them back in hey presto reverse lights again
thanks for the help
bit easier to work on the starlet than my ae101
GTCRSHR
