TRD coilovers.....rebuildable?
Postby aesc » Thu Sep 29, 2005 11:56 pm
Hi,
Well are they? Have heard some other brands are and and some arent. And what would actually need replacing when doing such a thing? Bit of a n00b here
EX AE101 owner
2013 Ford Focus ST
aesc
Postby nmemr2 » Fri Sep 30, 2005 3:50 am
and whats it going to cost, is it even worth rebuilding them
id say its just an excuse to upgrade and buy new stuff
who doesnt like new things
SW20, a work in progress for 2 years now, all i need to do now is work on it
nmemr2
Postby aesc » Fri Sep 30, 2005 9:42 am
At about $4000/set new then yeah it is worth trying to get them rebuilt :roll:
I dont have any at the moment but Im looking at getting a 2nd hand set from overseas, except the condition of them is unknown so I want a contingency plan in case they are stuffed.
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Mr Revhead » Fri Sep 30, 2005 10:36 am
its kind of a must see the item thing.....
if the valves are stuffed then most likely not, if its just leaking seals then most probably yes.
but the suspension shop really needs to see them apart to determine if they are or not
Postby TRD Man » Fri Sep 30, 2005 10:55 am
Depending on which set it is, some will have replaceable inserts.
Contact either Revhead or myself directly and we can advise on this.
You're probably looking at around $300 per shock.
TRD Man
Postby aesc » Fri Sep 30, 2005 11:34 am
They are just the standard TRD coilovers for ae101 Super Strut.
They appear to be in good condition ie not leaking but yeah revalving or new inserts sounds expensive.
Thanks for your replies
EX AE101 owner
2013 Ford Focus ST
aesc
Postby bad20v » Fri Sep 30, 2005 11:49 am
I'm goin to say the same thing:
Mr Revhead wrote:its kind of a must see the item thing.....
A visual inspection is the best way of determining the problem and giving you a solution. :D
Thank-You.
bad20v
Postby nmemr2 » Fri Sep 30, 2005 1:32 pm
ok i guess i see your point, im just not a fan of rebuilding/fixing something, i always prefer to go with new stuff, just makes me feel better
nmemr2
Postby aesc » Fri Sep 30, 2005 2:14 pm
Yeah true, and I can see your point too :wink: Im the same I prefer new over rebuilt with most things but in this case the cost is too much, my bank account would seriously kick my arse for it if I did :lol:
EX AE101 owner
2013 Ford Focus ST
aesc
