Caldina Brakes
Caldina Brakes
Postby Santa'sBoostinSleigh » Tue Oct 04, 2005 10:55 am
Is it just me or are Caldina GT-T brakes a bit crap for the type of vehicle that a Caldina is?
whats a good way to up the ante in the brakes department?
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Inane » Tue Oct 04, 2005 11:49 am
what pads are you using?
Inane
Postby Monster_Magnet » Tue Oct 04, 2005 11:52 am
Changin your pads would be the first option if you were keen enough maybe whole caliper swap from something else if you are serious about your brakes.
4 Pots off a JZA 80 supra any one??
Monster_Magnet
Postby Santa'sBoostinSleigh » Tue Oct 04, 2005 1:03 pm
i dunno, probably some shitters that were in it when i got the car
any recommendations for better pads?
Santa's Mega Sale
Postby Inane » Tue Oct 04, 2005 3:45 pm
cheap suggestion-
Lucas Pads, ~120 fronts, ~60 rears from repco
$ suggestion (but better) is
have them custom made up (as quite a few of the guys do)
roughly $250 (iirc) 0800BRAKES (www.0800brakes.co.nz)
I think thats the place but cant remember if ive confused them with someone else...
Inane
Postby blitza » Wed Oct 05, 2005 8:49 am
the pads you get from race brakes are bloody good, there are a few of us running them, but you do get plenty of dust on your wheels from them, I run mostly the ebc green from fbi, not as hard out as the mintex, but a lot cleaner.
MAD Industries Limited
blitza
Postby Inane » Wed Oct 05, 2005 10:03 am
blitza wrote:the pads you get from race brakes are bloody good, there are a few of us running them, but you do get plenty of dust on your wheels
I can wash my front wheels and they are black within about 10 minutes....
Inane
Postby Santa'sBoostinSleigh » Wed Oct 05, 2005 10:15 am
haha i'll have to definitely pass on them then!
i never end up getting round to washing my car as it is!
Santa's Mega Sale
Postby XERO » Thu Oct 06, 2005 9:30 pm
Try cleaning 16 spoke OZ racing superlights...
I use a toothbrush...
But yes new pads sorted my brakes,
I was also told low dust pads are not as good as regular pads...??
Altezza RS200 Z Edition
For performance parts :: www.drivenperformance.co.nz
XERO
Postby Santa'sBoostinSleigh » Fri Oct 07, 2005 8:26 am
i use a toothbrush on my mags anyway
end up with fux0red knuckles almost every time
did the same thing with my Advanti Nemesis mags on my old car as well
what are those green stuff pads worth?
Santa's Mega Sale
Postby caldinagtt » Fri Oct 07, 2005 5:12 pm
200 front 180 rear from raw motorworx i just got mine done with ebc green stuff there mint as.
caldinagtt
Postby Santa'sBoostinSleigh » Fri Oct 07, 2005 5:36 pm
jebus, thats pretty steep!
Santa's Mega Sale
Postby Malcolm » Fri Oct 07, 2005 5:52 pm
I bet st205 4 pot brakes would fit (maybe with similar mods as are needed for aw11's, st185s etc) 8)
Postby KinLoud » Fri Oct 07, 2005 9:16 pm
To help me help you...
explain what you mean when you say "Caldina brakes a bit crap"?
1 - Do you get brake fade,
2 - Do you have a long pedal,
3 - Do you have a soft pedal,
4 - Do you have a hard pedal,
5 - Are the brakes very sensitive (not much pedal pressure, car stops quickly)
6 - Are the brakes not sensitive (loads of pedal pressure, car stops slowly)
Pick the one/ones that best describe your problem then I might be able to suggest some solutions.
Without knowing what you think you don't like about your brakes...
Change the brake fluid, get toyota genuine pads, get the brake disks skimmed. Also try to drive other examples of the same car as yours so you can know if you car is the same or different to the others.
Ken
Ham
021 408 863
Postby Santa'sBoostinSleigh » Mon Oct 10, 2005 8:31 am
probably the best description would be put foot down hard, car doesnt slow down to a stop in a hurry
plus ABS sucks
also pads squeak, but thats cause they are crappy pads
Santa's Mega Sale
Postby TWSTD » Mon Oct 10, 2005 1:54 pm
For EBC go straight to Hitech in Newmarket. Mine were $165 I think (fronts). You cant go past mintex M1166's for track use (just gettin mine redone at BNT - they bond and rivet the material to your old backings).
I find EBC green relatively clean - but not a patch on the mintex performance wise.
Click here!
TWSTD
Postby KinLoud » Fri Oct 14, 2005 11:40 pm
Sounds like a pad problem to me
I had EBC greenstuff in my GTZ trueno.
Cold - braking action poor (only just pass warrant)
Warm/Hot fantastic.
I would start by getting Toyota factory pads - they will work well cold and still be pretty good hot. Skim the disks as well.
Maybe get a second set of pads for trackdays etc. Only takes about 10 minutes to swap a set of pads at the track once you have done it a few times.
Drive some other GTTs to see if its just your car.
Ken
Ham
021 408 863
Postby BigDon » Sat Oct 15, 2005 5:24 pm
IMO and experience EBC Green Stuff are very average, Mintex 1166 are very very good and work relatively well when cold (no drama with warrants).
Had the EBC's on my AE101 FX and went to Mintex and will never look back. IMO who cares about brake dust, do you want good brakes or not. I have 17inch VX1's and they are a PITA to keep clean but what’s a bit of extra cleaning when it makes such a dramatic improvement to the brakes.
I got the majority of my brake set up direct from Race Brakes the guys there know there stuff and give very good deals to TS people. Check out this link for some detailed info:
http://www.toyspeed.org.nz/sponsors/Mas ... e_Info.doc
Depending on how many K's your GT-T has done and whether the rotors are down to their tolerance thickness or not you could consider the following upgrade which I have done to my FX (which I admit is no where near as heavy as your GT-T would be) but can't fault (pretty good value at just over approx $1000 a year ago excl braided lines and fitting) for what it has given me in terms of brakes, pulls up faster, never fades):
Brembo vented Slotted Rotors in the front;
New Factory rotors in the rear (couldn’t get slotted);
Mintex 1166 pads all round;
Elf XT3167 mineral fluid; and
I have just had Mossrax in Wellington put in a full set of braided hoses.
You could also consider bracing your master cylinder which can firm up pedal feel by limiting firewall flex, which should mean you can apply more pressure faster (same sort of theory as braided lines I believe).
www.europeandirect.co.nz
1996 AE111 BZ-G: TRD equipped road legal Club Car (Manfeild 1.25s) (SOLD)
1995 AE111 BZ-G: Stereo and daily driver (SOLD)
2005 NZ New Evo 9 GT (specd to FQ360) daily driver
2012 NZ New Outlander VRX - V6 family wagon
BigDon
