FPR needed with PFC??
Postby KiwiMR2 » Tue Oct 04, 2005 12:07 pm
My Power FC has arrived :twisted:
I was told previously when I did my dyno run that to fix the running lean etc. an an aftermarket fuel pressure regulator would sort it....now that I have the Power FC I probably won't require that now aye??
KiwiMR2
2003 Estima 3.0L
2000 Opa
KiwiMR2
Postby Monster_Magnet » Tue Oct 04, 2005 12:30 pm
Should do power FC's are pretty good but if they said AFR then asj them what there logic is behind it.
Monster_Magnet
Postby JamesM » Tue Oct 04, 2005 1:39 pm
with pfc u can run bigger injectors without the need to run such high pressures to get more fuel out of your old undersized injectors.
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
Postby Akane » Tue Oct 04, 2005 2:31 pm
If you're keeping your ct20b, I don't think you should use an FPR.
I've been toying around with the idea of adding a FPR to my 550's to raise them from 531cc (lower MR2 pressure) to around 580's (if raised to around 50psi IIRC) before heading to dyno tune.
But I ain't shooting for mega power so I think that should be okay.
check what duty cycle you're running at first. keep an eye out on your knock. post results.
Postby KiwiMR2 » Tue Oct 04, 2005 3:11 pm
Akane wrote:If you're keeping your ct20b, I don't think you should use an FPR.
I plan on keeping the CT20b, I'd like to think the 540's would be able to keep up :)
I'll post the results......I might have a go at plugging it in tonight 8O
KiwiMR2
2003 Estima 3.0L
2000 Opa
KiwiMR2
Postby KiwiMR2 » Tue Oct 04, 2005 8:52 pm
Well I plugged it in, car started fine so that was a good start 8)
I did the learning thing for 10 mins, then went for a bit of a blat to get gas. My 1st impressions are it doesn't really feel any different......possibly a tad smoother but not a great change. I was a bit hesitant to give it death so started on the low boost setting on my Profec. That was fine for 2 mins so I had a go on the high setting (around 16 psi) and again it seemed to be fine (but I didn't quite floor it to the max) and I get no check engine lights at any point of my journey.
I ran out of light so i couldn't run the commander into the cabin (what is the best route for this??) so unless it stores your last run data Im not really sure what it was reading, I had a bit of a fiddle but need to sit down and read the instructions (having a look now).
So yeah
KiwiMR2
2003 Estima 3.0L
2000 Opa
KiwiMR2
Postby Akane » Tue Oct 04, 2005 10:50 pm
I had to buy the APEX'i cable extension to have my Hand controller to be in the cabin. Or you can be like Wildcard and rangi one up from jaycar.
I used to run my 440's @ 90.2% injector cycle, at 1.01 kg/cm^2
I can feel the love already :) Ring your car out to redline and see if you reach 85%, that's the safe zone.
Postby vvega » Tue Oct 04, 2005 10:53 pm
Akane wrote:I had to buy the APEX'i cable extension to have my Hand controller to be in the cabin. Or you can be like Wildcard and rangi one up from jaycar.
wildcards middle name is rangi :D
vvega
Postby KiwiMR2 » Wed Oct 05, 2005 7:11 am
I thought ahead and ordered one along with the unit on day one ;)
Which is the best route to take it into the cabin?? and where do people usually monunt them??
KiwiMR2
2003 Estima 3.0L
2000 Opa
KiwiMR2
Postby Wildcard » Wed Oct 05, 2005 8:30 am
KiwiMR2 wrote:I thought ahead and ordered one along with the unit on day one ;)
KiwiMR2
Cable tied to the air vent ;) but then again Ive never intended for the HC to be sitting in my car the whole time. After my tune is stable I'll be putting mine back in the cupboard.
Wildcard
Toyspeed Founder
Postby Akane » Wed Oct 05, 2005 2:23 pm
route mine thru the gearshift cables.
Gotta show the ladies the bling..... gotta show....
Postby Bazda » Wed Oct 05, 2005 6:52 pm
I have some FPR's for sale if you guys need one....
Postby Akane » Wed Oct 05, 2005 7:25 pm
I have checked the yank board last night.
If what they said was right, putting an FPR on our cars is a waste of time unless we upgrade the fuel pump.
Because our pump cannot maintain flow if the pressure is high.
I was JUST ABOUT to buy the aeromotive kit for our car, for $139 USD (includes all fitting), then I spent another 20 mins and checked that it's a waste of time.
And the Gen 2 fuel rail is crap too (so they say).
Postby KiwiMR2 » Wed Oct 05, 2005 8:29 pm
Hey what is controlling the boost when the pfc is plugged in?? I hit what felt like fuel cut while boosting in 5th gear on the motorway tonight, I didn't see a check engine light though :?: I had my profec on the normal hi setting (16 psi) but I was reading today that there is a certian level of boost control via the pfc.....even without the additional boost control kit?? Would the pfc be setting it to a certian level and then my profec trying to make it go higher??
KiwiMR2
2003 Estima 3.0L
2000 Opa
KiwiMR2
Postby Akane » Wed Oct 05, 2005 9:21 pm
If you buy the optional boost control kit, you can control the boost and do a lot of weird stuff with it.
When you hit what felt like a boost cut, did you check your peaks? The check engine light only flashes momentumly, you gotta check your peaks with the hand controller to know more.
Your Gen 3 sensor should go higher than 16psi, I know the gen 2 MAP sensor only goes upto 1.2kg/cm^2 before it spaz out.
Postby KiwiMR2 » Thu Oct 06, 2005 6:36 pm
Ok well again I tried boosting in 5th at 100 kph......it started to boost and bang, again what feels like fuel cut :? I checked the hc once home and it read my highest boost pressure as 1.03 kg/cm, that must be were I was stopped.
I noticed in the manual it says "When using a boost controller other than the power fc, be sure to set the power fc boost to a level where fuel cut will not occur"
It also says "If the boost rises 0.25 kg/cm over the preset boost levels, a fuel cut occur thereby notifying the user of a boost control problem"
remeber I haven't changed anything in the hand controller.....is there some "base map" setting that is limiting me from going over 1.03 kg/cm?
KiwiMR2
2003 Estima 3.0L
2000 Opa
KiwiMR2
Postby Akane » Thu Oct 06, 2005 11:21 pm
go to etc, and check the "Boost controler kit" is set to ナシ
