I was told previously when I did my dyno run that to fix the running lean etc. an an aftermarket fuel pressure regulator would sort it....now that I have the Power FC I probably won't require that now aye??
KiwiMR2
Akane wrote:If you're keeping your ct20b, I don't think you should use an FPR.
I've been toying around with the idea of adding a FPR to my 550's to raise them from 531cc (lower MR2 pressure) to around 580's (if raised to around 50psi IIRC) before heading to dyno tune.
But I ain't shooting for mega power so I think that should be okay.
check what duty cycle you're running at first. keep an eye out on your knock. post results.
Akane wrote:I had to buy the APEX'i cable extension to have my Hand controller to be in the cabin. Or you can be like Wildcard and rangi one up from jaycar.
I used to run my 440's @ 90.2% injector cycle, at 1.01 kg/cm^2
I can feel the love alreadyRing your car out to redline and see if you reach 85%, that's the safe zone.
KiwiMR2 wrote:I thought ahead and ordered one along with the unit on day one
Which is the best route to take it into the cabin?? and where do people usually monunt them??
KiwiMR2
