kilowatts wrote:I Thought the caldina beams engine is 210 hp .Thus meaning the japanese toyota specs i read are wrong. Anyway i think paying a little extra for either beams engine would be a better option. Or use the head off the beams and bolt up to your gen 3 block.
anthonym wrote:Malcolm, I respectfully suggest you harden up, your proposal is a false economy, the cost of running a second car will easily outweigh any damage you might do to your so called SW11, as well as being slower than dave on his skateboard.
All_Fours wrote:the difference is that an NA aw11 would be more economical and safer (esp. in the case of my gf racing it) to race competitively than the 3sgte powered one. to make the 3sgte powered one competitive in 2wd turbo classes means it would have to be running very close to 10s (to stay out of the pro class), whereas an NA would be competitive running 13's.
I did realise a problem though, which is that in the NSDW competition NA's includes rotaries, of which there were a couple running high 11's last season. Maybe I should just give up on racing anything competitively for another 4 years when I'll be out of uni...
kilowatts wrote::oops: Sorry i assumed the blocks were relatively similar.Assuming is the mother of all f-ck ups.
anthonym wrote: If you stick to a hp limit I'll be safer and you won't break it,
RS13 wrote:As a side note, there was a yellow SW20 with 3SGE, only had a pod filter and large muffler, which ran a 14.4 down here a while ago. It was running 17s as well.. I'd assume with a few more HP in a lighter AW, you'd easily be in the 13s?
Al wrote:The yellow one with the veilside kit? That had a claimed 14.8 on his for sale ad.
