flywheel machined
flywheel machined
Postby LEV_101 » Mon Oct 10, 2005 5:40 pm
does anybody know where i can get my flywheel machined somewhere in auckland thanks. car having funny problem i step on full gas and the rpm goes really fast to 5000ish rpm and stops there and when i change gears and step on gas it does the same thing. i think it would be the flywheel, if not can stop one help! if it was, which would be better. go get my silvertop flywheel machined or get a blacktop flywheel?
LEV_101
Postby jailbird » Mon Oct 10, 2005 5:47 pm
sounds like ur clutch is sliping
my car did that,
:twisted:
jailbird
Postby Ae92typeX » Mon Oct 10, 2005 6:39 pm
as said, the flywheel wont be the problem.
but...
if you do do the clutch you will want to get the face machined (especially if clutch has been slipping bad) most places that sell clutches can get them machined (excluding shops like repco) depending where you are in auckers tradeparts always give me excellent service.
Ae92typeX
Postby Silent Knight » Mon Oct 10, 2005 6:51 pm
Yup...I will vouch for Trade parts aswell.
If you get a clutch/pressure plate combo through them they normally give your flywheel a machining for free.
Silent Knight
Postby sergei » Mon Oct 10, 2005 7:49 pm
Trade parts, good deals on clutches, free machining, if u don't get clutch but want just machine the flywheels it is ~$60 from memory.
Postby nmemr2 » Mon Oct 10, 2005 7:51 pm
yea i would say it would have to be the clutch too.
happened to me a while ago, it kinda creeps up on you, bitch of a job though
SW20, a work in progress for 2 years now, all i need to do now is work on it
nmemr2
Postby LEV_101 » Mon Oct 10, 2005 8:07 pm
OM_G so damn poor. . . o well, i guess ill have to get it checked and maybe changed. what is the differents between the high duty clutch and the normal ones? and how much is this going to be setting me back :( ?
LEV_101
Postby nmemr2 » Mon Oct 10, 2005 10:25 pm
IMO. the heavy duty ones grip harder and faster (generally Brass button style)
whereas the regular ones are smoother and generally easier to use.
if its strictly for street go for the normal one but if you drive hard or intend to do some racing with it get the heavy duty one.
i got a heavy duty brass button option when i had mine done and it set me back a tidy $400 for the product
and, as im useless when it comes to that kinda thing i paid to have it put in costing just less than that much again
nmemr2
Postby LEV_101 » Mon Oct 10, 2005 10:41 pm
thank you you guys for replying ... helped me so much on what i am going to do ... are there any brand i should want to be getting ... or watch out for what shop to go to... thanks again so much ! :D your help has been great
LEV_101
Postby nmemr2 » Mon Oct 10, 2005 10:47 pm
Daiken have a good range
they should have something for your car
nmemr2
Postby Ae92typeX » Mon Oct 10, 2005 11:57 pm
If you can't do the clutch yourself make sure you shop around for quotes, a variance of $200 isnt uncommon.
as said, if its just a road car a standard clutch will be fine...anythings better than a worn out one anyway!
Ae92typeX
Postby LEV_101 » Tue Oct 11, 2005 6:31 pm
so it should be round about 200ish and plus. cheers ae92! with my worn clutch still in my car ... will it damage anything ? or can i leave it in for a bit longer ? cheers
LEV_101
Postby Ae92typeX » Tue Oct 11, 2005 6:39 pm
sorry, perhaps I wrote it unclear (or read your reply the same). You may be looking at around $500ish for a clutch and fitted $100 either way...depending where you go. Years ago I was quoted $580 by toyota for a clutch on the ole ae92, but got it done for $300 elsewhere. Im not 100% up with the prices now as I do my own and my mates business ones for ~15-20$h
As far as damage goes, it most likely you will just loose all drive as the clutch burns out. It will mark the flywheel, but usually a good stonegrind will make it fine.
Ae92typeX
Postby LEV_101 » Wed Oct 12, 2005 7:41 am
hey thanks so much for helping me :) .... maybe ill let it burnout and then go look for one at some places ! thanks guys
LEV_101
