KP Starlet questions.
Postby RomanV » Fri Oct 14, 2005 1:03 pm
Ive just picked up a 4 door KP60 with a 4K in it. :P
It is GREAT fun to drive. Nowhere *near* as fast as the MR2, but *far* more fun. :)
Anyway, I have a few questions.
1. The steering wheel sucks. Its like a thin peice of wire with plastic wrapped around it. :? Are there other Toyota steering wheels that will fit? Preferably something smaller and more rigid. And cheap. :mrgreen:
2. The seats are CRAP. You cant go around a corner without sliding off your seat. Are there any other seats which bolt in, which are a little better? I think Ive heard of people using AW11 seats, or AE92 seats?
3. Do all K40/K50 gearboxes have the same gear ratios?
4. What diff ratios are there? Ive still got the low ratio diff that I think came with the 2k motor that was originally in the car.
Re: KP Starlet questions.
Postby bad20v » Fri Oct 14, 2005 1:16 pm
RomanV wrote:1. The steering wheel sucks. Its like a thin peice of wire with plastic wrapped around it. :? Are there other Toyota steering wheels that will fit? Preferably something smaller and more rigid. And cheap. :mrgreen:
Yeah... Nah. Just get a cheap one off Tard Me. I got one that was only $25 for mine and it came with a Boss Kit too. :D
RomanV wrote:2. The seats are CRAP. You cant go around a corner without sliding off your seat. Are there any other seats which bolt in, which are a little better? I think Ive heard of people using AW11 seats, or AE92 seats?
Put them out and throw them away. Get some FX-GT seats or something as comfortable for replacements. I don't think they will just bolt straight in but you should be able to make new rails or adapt them to fit properly. :D
RomanV wrote:3. Do all K40/K50 gearboxes have the same gear ratios?
Pass. i dunno. :(
RomanV wrote:4. What diff ratios are there? Ive still got the low ratio diff that I think came with the 2k motor that was originally in the car.
Pass again. I just use it for skids at the motorkana's mostly. :P If it breaks I have another one that is a donor car, same model, that I pull parts off. :D
Thank-You.
bad20v
Postby RE20 » Fri Oct 14, 2005 1:23 pm
For seats, can you weld? do a little fab? If not a good mechanic will be able to do it prob cost a couple of hours labour talk to them nice and you might get a deal :wink: I have GTX seats in mine and its great :D
In the event of nuclear catastrophe, the only survivors will be Cockroaches and Toyota K series engines...
pervert wrote:Haha, it's not low enough, it still has suspension travel!!!
RE20
Postby Dell'Orto » Fri Oct 14, 2005 6:07 pm
I believe K40's and K50's share the same ratios, and the auto diff's are the really low geared ones.
Postby fangsport » Fri Oct 14, 2005 6:52 pm
one of the early Corollas had different ratios in it, maybe KE25.
good luck finging one , as the race/rally boys have killed most of them.
fangsport
Postby QikStarlie » Fri Oct 14, 2005 6:55 pm
seats out of the sprint model are a whole lot better
QikStarlie
Postby MikeMan » Sun Oct 16, 2005 9:40 pm
MikeMan
