The guys a Tard, you dont have an air flow meter, you have a map sensor, So yes you can put a pod filter on it, IMO i would buy a K&N replacement panel filter, Filters well and is cleanable and will restrict a lot less than a standard filter,
A pod filter sucks in warm air from around your engine bay unless you build a cold air box
I have an HKs panel filter which is made of foam, im a bit cagy about it disintegrating over time and ending up in my engine somewhere
So yeah, if i had to, i would go for the K&N replacement
