Switch on clutch?? (with pic)
Postby Rick » Mon Oct 24, 2005 10:24 am
Have been in the process of modifying my clutch pedal and couldnt help but notice the switch on the clutch pedal, what does this do??
Postby eightytrueno » Mon Oct 24, 2005 10:36 am
ae85 pedal box? converting to hydro? just did same thing. cant answer your question tho..
eightytrueno
Postby ATAl » Mon Oct 24, 2005 11:04 am
On American cars the clutch has to be pushed in to start the car, that switch could be a leftover from the same kind of system that has been disabled.
ATAl
Postby Ae92typeX » Mon Oct 24, 2005 12:09 pm
as said, is wired onto many cars so it has to be pressed in to start the vehicle. Was more common in american market cars, but ive seen an increasing amount of new nz cars getting it also.
Ae92typeX
Postby Rick » Mon Oct 24, 2005 12:40 pm
eightytrueno wrote:ae85 pedal box? converting to hydro? just did same thing. cant answer your question tho..
Yip AE-85 pedal box, converted to hydro, couldnt find a AE-86 pedal box so I had to modify my one to suit. What master cylinder did you use?
ATAl wrote:On American cars the clutch has to be pushed in to start the car, that switch could be a leftover from the same kind of system that has been disabled.
I didnt have to put the clutch in to start, so I guess I can remove the wiring for it then?
Postby ATAl » Mon Oct 24, 2005 4:53 pm
Unplug it, check everything still works, then remove it.
ATAl
Postby eightytrueno » Mon Oct 24, 2005 9:38 pm
i ended up buying a brand new ae86 master cylinder from BNT, as a friend managed to hook it up at a good price. i'm not sure if it is goin to be enough for my new bigger brakes though.
yeh i'm pretty sure mine was never plugged into anything, so shouldnt harm taking it off!
eightytrueno
