16v 4agze crank the same as 20v blacktop?
Postby oldskool_rwd » Wed Oct 26, 2005 7:48 pm
oldskool_rwd
Postby ATAl » Wed Oct 26, 2005 9:08 pm
Yes, same part, but, 20v crank is a bit straighter from factory.
ATAl
Postby NZ_AE86 » Wed Oct 26, 2005 9:08 pm
Yes
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby Mr Revhead » Wed Oct 26, 2005 10:27 pm
straighter? wtf?
but yes, the exact same part
Postby ATAl » Thu Oct 27, 2005 7:26 am
The specs call for it to have less bend. ( I think )
ATAl
Postby RedMist » Thu Oct 27, 2005 8:30 am
ATAl wrote:The specs call for it to have less bend. ( I think )
Correct, the ZE crank has a total of 4 degrees of deflection from center while the 20 valve crank is speced to only have 2. Hence why the ZE mains are slightly more oval than the 20 valve.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Mr Revhead » Thu Oct 27, 2005 9:39 am
well, the specs are for the bearing clearances, i guess that could be interpreted as allowing more tolerance in the crank... buts its more bearing clearance...
the ze and 20v crank are the same part.
Postby oldskool_rwd » Thu Oct 27, 2005 8:40 pm
ok thanks alot for ur help guys :D
oldskool_rwd
Postby RedMist » Fri Oct 28, 2005 6:32 am
By the way, everything I stated was total bollocks! Oval bearings? Bent crank?
The clearances may be slightly different. But thats it.
RedMist
Postby vvega » Fri Oct 28, 2005 7:54 pm
lol time to stop the p smoking aye redmmist
:D
vvega
Postby vvega » Fri Oct 28, 2005 7:57 pm
attually no keep up the habbit but can i have some :d
v
vvega
