twin carbs on 4k??
twin carbs on 4k??
Postby dx_conversion_4age » Thu Oct 27, 2005 10:50 pm
hey im thinking of putting some twin carbs on my 4k, just wondering that effects it will have if any thanks. oh i was ony thinking of putting the standard toyota one on it
dx_conversion_4age
Postby vhpacer » Fri Oct 28, 2005 9:50 am
If they are of a 3k (which they probably are) they will make no difference in power just an increase in fuel consumption. But if you get them properly tuned they can make a good increase in power. You would be better finding a twin throat webber off a 2.0 ltr cortina. They are called a 32/36 and get that tuned. It would give way better fuel consumption and probably give more power than the twins.
vhpacer
Postby Dell'Orto » Fri Oct 28, 2005 10:27 am
Twin sideys is where its at :twisted:
Expensive to buy, set up and on fuel....but man, they sound so cool :D
Give a pretty handy increase in power if done right too.
Postby spencer » Fri Oct 28, 2005 11:37 am
I'd say twin sideys are only realy worth going for on a 4k if you have done other mods (or plan to) like a cam, compression and abit of port work.
spencer
Postby Jebus » Fri Oct 28, 2005 12:07 pm
Down draught webers are ok, but a good but overlooked carb are 2T twin down draughts. Theyre about 40mm so maybe 36mm choke size or around there, not too hard to fit. I was running some on my 5K for a bit and it made descent power for a 5K, although it had alot of other work.
Jebus
