Noise when engaging reverse gear...
Postby pervert » Fri Nov 11, 2005 12:42 pm
KE70 with a 4K and K40.
When you push the clutch in and select reverse, it makes a loud grind/clunk sort of noise...only does this when selecting reverse.
Anyone point me in the right direction for what I should be looking for?
pervert
Postby z|gen » Fri Nov 11, 2005 12:44 pm
just getting old - syncros are wearing out
AE91 SUPERCHARGED COROLLA
z|gen
Postby pervert » Fri Nov 11, 2005 12:51 pm
Nah, I don't think it is that.
Have had the car a few weeks, and it used to be fine, then I went to engage reverse last night, and it just started doing it...it's quite loud, not something that has gradually crept up... :?
pervert
Postby Jebus » Fri Nov 11, 2005 1:00 pm
Put it in second, then reverse. Is it smooth then?
Jebus
Postby pervert » Fri Nov 11, 2005 1:06 pm
Jebus wrote:Put it in second, then reverse. Is it smooth then?
Yup, it's smooth if you engage a gear first, as long as you don't push the clutch in and out between shifts and just hold the clutch in the whole time.
pervert
Postby ollieboy » Fri Nov 11, 2005 1:43 pm
I thought it was normal, all the Toyotas we have ever owned have done this.
ollieboy
Postby pervert » Fri Nov 11, 2005 1:45 pm
ollieboy wrote:I thought it was normal, all the Toyotas we have ever owned have done this.
Haha, I think you're under-estimating this noise... :lol:
I don't think you're quite cut out for the tech section...I'm after help here...
pervert
Postby RomanV » Fri Nov 11, 2005 1:48 pm
IIRC you dont have synchros in reverse, only straight cut gears. hence the 'whine'.
But perverts problem sounds like something else.
Im fairly sure I know *exactly* the noise you are talking about, had the same thing in my starlet. But in every gear. :lol:
I havent pulled it the old gearbox apart yet to have a look though.
Have you tried checking the Gbox oil level? Mine died from lack of oil. :?
Postby pervert » Fri Nov 11, 2005 1:55 pm
RomanV wrote:Have you tried checking the Gbox oil level? Mine died from lack of oil. :?
Nah, I haven't got that far yet...the rest of the box's operation seems fine though...
pervert
Postby RomanV » Fri Nov 11, 2005 1:57 pm
Mine sounded like.... having your ear right up to a washing machine full of spoons..... and horrible scraping metal sounds. :?
All gears still worked, it just sounded unbearably horrible.
Postby CozmoNz » Fri Nov 11, 2005 2:09 pm
Sounds like its being droped into, not engaging.... sort of thing?
Occasionally all my cars have done this (bar the subie, which just was an ARSEHOLE to get into reverse).
I just make sure i push it into second or third before selecting reverse.
i thought real men dont care about noises :P SHELL BE RIGHT, just kick it :D
Rayne For President!
CozmoNz
Postby pervert » Fri Nov 11, 2005 3:05 pm
Please refrain from making posts in my tech section threads Cozmo, I would never listen to a word you say...not to mention the fact that you are offering no help at all, no offence and all...bye... 8)
RomanV> You described the noise rather well!!! That sounds just like mine... :lol:
pervert
Postby EVL20V » Fri Nov 11, 2005 5:26 pm
mayb u should try using the clutch ow! :lol: :lol:
na thats an oldie. :lol:
i just slap it in 2 4th then quickly in2 reverse every time. my 2c :twisted:
EVL20V
Postby pervert » Fri Nov 11, 2005 5:34 pm
Yes, that does work...but I can't understand why it would be perfectly fine, then next time it's really $&#$% bad... :lol:
Syncros wear, they don't just give out instantly right... :?
pervert
Postby Silent Knight » Fri Nov 11, 2005 5:39 pm
Reverse is straight cut...
It might a broken little metal piece inside the box which is floating around and got stuck. That way when you put it into revers that piece might be getting caught in the rotating parts and making that sound somewhere?
I have seen this happen....the only way to verify really is to remove gearbox and take apart.
Just a suggestion to what it might be.
Silent Knight
Postby EVL20V » Fri Nov 11, 2005 5:45 pm
basically we mean we have no $!*$@% idea! :lol:
get the $%#$% gearbox out and take a look :lol: :D
EVL20V
Postby pervert » Fri Nov 11, 2005 5:51 pm
EVL20V wrote:basically we mean we have no $!*$@% idea! :lol:
Hard to do that when sitting at work, which is why I asked here first, thinking someone might know. :lol:
Silent Knight> Thanks!!! 8)
pervert
Postby Lloyd » Fri Nov 11, 2005 8:56 pm
Is your clutch adjusted properly? If its still just dragging and spinning the input shaft slightly then it'll go into gear nicely due to synchros, but would grind going into reverse due to straight cut gears. Just a maybe...
Postby l1ttle_d3vil » Fri Nov 11, 2005 11:28 pm
my ke35 / 4 speed done the same thing, so i put a 4age with a t50 in and it still does it :twisted: I think thats cos my clutch isn't working properly now though - i need slightly more throw on my pedal or something. :oops:
Postby vvega » Sat Nov 12, 2005 7:20 am
1st and reverse have no syncro's
reverce is strait cut
it making the noise only whilke inguaging or when attually moving as well ??
if its just inguaging you need a new clutch or your cable has streched and that needs replacing
if its while moving as well you need to get a new box ..sounds like yourve bured the gear and its not riding nicely anymore
v
vvega
