Gearbox oil for AE92 GT-Z...
Postby peas » Fri Nov 11, 2005 7:36 pm
Just wondering if people know what should be run in these as it has a LSD. Not sure if they are shared or sealed or viscous or what. I have looked them up at work in the catalogs, called Castrol's helpline and then Toyota but still nothing conclusive.
'97 Caldina GT (ST215G)
peas
Postby Lloyd » Fri Nov 11, 2005 8:57 pm
They're viscous. Just use Castrol VMX or silmilar.
Have a search too, this has probably been covered a couple of times
Postby peas » Fri Nov 11, 2005 9:55 pm
Yeah done the search thing but turned up nothing useful. VMX is 80w I think from memory, I was goinf to go for 75w90 semi syn but well if the diff is viscous then it may affect it. What are others using in theirs?
peas
Postby Lloyd » Sat Nov 12, 2005 8:06 pm
Go for 75/90 if you wish. The viscous unit is completely sealed so for transmission oil just treat it as though it was any other manual.
Postby vvega » Sat Nov 12, 2005 8:38 pm
oi you its not sealed!!!!
only the 101's have the viscous
he should have a plate type!!
v
vvega
Postby Lloyd » Sat Nov 12, 2005 10:13 pm
Seriously? I was under the impression that all the GZE boxes were viscous. In that case, ignore me :)
Side note: I'm assuming the late model MAPed AE92s were viscous also then?
Postby vvega » Sat Nov 12, 2005 10:25 pm
HRT wrote:Seriously? I was under the impression that all the GZE boxes were viscous. In that case, ignore me :)
you would have to find out the box code :D
v
vvega
Postby sergei » Sat Nov 12, 2005 11:22 pm
There is other possibility - Torsen...
Many people mistake Torsens with viscous.
Don't know about AE92 GTZ g/box (late ones from AE101 had plate LSD - try turning wheels in neutral opposite ways while jacked up) but my C160 has torsen in it, behaves similar to viscous but it is feels better (lack of lag)..
Postby vvega » Sun Nov 13, 2005 6:39 am
nah no torsens have ever been avalibile for that paticular box :(
if they wor id have one over the plate that i have in mine
much nicer lsd in concerns to not upsetting the car underpower or in braking :D
v
vvega
Postby ae82charged » Tue Nov 15, 2005 7:40 pm
I spoke to palmside performance and they said they can get quaife ATB's "torsens" for the E51, E58 gearbox
ae82charged
Postby vvega » Tue Nov 15, 2005 7:47 pm
http://www.quaife.co.uk/products/atbdifferentials.htm
yeap they can
thats cool i checked last year on this same page and they were metioned :D
i really wanted one for my mr2 rather than a plate type
v
vvega
