AE92 4AGE Jerking Problem
Postby varix » Sat Nov 12, 2005 2:34 pm
Just recently my car has started jerking at low rpm in all gears, its not really bad, and seems to go away once the car is at normal temp. When driving along at say 2000rpm in 4th gear, and releasing the gas, the car jerks, untill you reapply gas. ( the jerking is similar to putting ure foot on and off the accelerater really quickly).
I have heard that it could be a fuel pump, or perhaps throttle cable, although i dont see how throttle cable could cause this type of problem.
Any help/ideas would be appreciated thanks
varix
Postby CAMB01 » Sat Nov 12, 2005 6:44 pm
Throttle position sensor
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby l1ttle_d3vil » Sat Nov 12, 2005 8:43 pm
my car seems to have a similar problem - not sure if its the same as what you're describing or not. its as if there is no "inbetween" on or off the accelator, you're either off the gas and slowing down or on the gas and speeding up. makes for a difficult time when you're trying to hold a steady speed through town...
is this likely to be the TPS as well?
Postby ee904age » Sun Nov 13, 2005 9:44 am
Yeah TPS would be the first thing to check for both of you. Mine did the same after changing the TPS and then after calibrating it the problem dissappeared.
Check the FAQ section for the specs and how to calibrate it.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby varix » Sun Nov 13, 2005 4:47 pm
Okay, cool, i have looked around the FAQ section but cant really see any decent instructions. I found the specs for the TPS, but how to apply these to the car? lol. Would it be easier to find a mechanic to do it for me? Or is it reasonably easy. Thanks
varix
Postby l1ttle_d3vil » Sun Nov 13, 2005 5:19 pm
i have had my TPS calibrated professionally a couple of days ago and it hasn't fixed it.
Postby ae82charged » Tue Nov 15, 2005 7:35 pm
R the engine mounts broken???
ae82charged
Postby varix » Wed Nov 16, 2005 9:58 pm
Ahhhh, would i stil have an engine in the engine bay if they were?
varix
Postby matt dunn » Wed Nov 16, 2005 10:15 pm
varix wrote:Ahhhh, would i stil have an engine in the engine bay if they were?
We get quite a few car in for surging / jerking / missing
where it turns out to be broken engine mounts.
V6 toyota camry and windoms especially.
Postby ollieboy » Wed Nov 16, 2005 10:25 pm
Yeah my old Civic had broken engine mounts and I jerked everywhere I went. (bl*ody Hondas :roll: )
Also I am surprised noone made some crack about Masturbating being that its about jerking.
ollieboy
Postby Jebus » Wed Nov 16, 2005 10:26 pm
Could be to do with the fact that were not at school :roll:
Jebus
Postby varix » Wed Nov 16, 2005 10:27 pm
Haha^^
Yeah very interesting, sorry i never thought about the actual mounts, is their any easy way of checking their condition?
varix
Postby ollieboy » Wed Nov 16, 2005 10:30 pm
I was surprised because some of the other things people have said on TS have been pretty immature. I was good surprised if you know what I mean because I sure don't. Surprised as in good on you for not being a dick. I digress, oh my goodness I have become what I despise, I will shut up now.
ollieboy
Postby Spannergal » Wed Nov 16, 2005 10:31 pm
if you know where they are in the engine bay, you can check them visually with a torch, will generally tell you whether they are bent or broken. should generally be fairly easy to locate
Spannergal
Postby varix » Wed Nov 16, 2005 10:33 pm
Sweet, ill have looksy in the morning and see how it goes, if it turns out to be the mounts, this could be a costly exercise right?
varix
