Rust repair help
Rust repair help
Postby Zak » Tue Nov 15, 2005 7:09 pm
Hey, I just got my new ae85, and as any ae85 it has rust, it's not too much, but where it is, it's pretty bad eg. holes :(
How much does it cost to get rust cut out and rust proofed?
I don't really care about the look for now, but would like to paint it at a later stage.
Is there any good way to get rid of surface rust, before it gets worse?
Also, any tips from some one that has had to get rust fixed before?
Cheers :D
Zak
Re: Rust repair help
Postby z|gen » Tue Nov 15, 2005 7:17 pm
Zak wrote:Hey, I just got my new ae85, and as any ae85 it has rust, it's not too much, but where it is, it's pretty bad eg. holes :(
Cheers :D
Cost depends on who does it and how bad it is, i know a place down here all they do is just weld in plates, everything else is done by you,
surface rust - get a wirebrush on it or a grinder and remove it that way and then treat it and paint over.
AE91 SUPERCHARGED COROLLA
z|gen
Postby Zak » Tue Nov 15, 2005 7:25 pm
Thanks, I'd rather not touch the bad stuff at all, but I'm up for giving the surface rust a go, I just don't want it coming back.
Also roughly how long does each plate welded in take?
Zak
Postby z|gen » Tue Nov 15, 2005 7:31 pm
depends who does it and there workload..
i suggest you pick up the phone and ring some places.
z|gen
Postby Ae92typeX » Tue Nov 15, 2005 9:01 pm
z|gen wrote:depends who does it and there workload..
additionally how big the patch and the shape of it.
Also worth asking what they actually do when ringing for prices. some cheaper options only weld a plate over the top of it all (as is). You really want the old stuff properly cut out, rust killed then the new plate welded in so you can give it a little grind and blend it in with filler later when you prep to paint.
may sound stupid, but any rusty areas you are not looking at straight away could be coated in a brush of old engine oil- generally helps slow the process down. Just make sure you clean it damn good before any prep paint work in the future.
Ae92typeX
Postby Zak » Wed Nov 16, 2005 6:18 pm
I went and saw the rust repair dude today, he said it's about $1000 worth :(
But thats ok, caus it's cheaper than buying another, possibly rusty ae85, but he's all booked up till about feb :?
So I need to get it done in auckland, any one got any recomendations?
I don't need it painted, just the rust fixed and rust proofed for now.
Cheers :D
Zak
Postby vhpacer » Wed Nov 16, 2005 6:49 pm
You can get rust converter stuff for surface rust, dont know how good it works though. But $1000 sounds pricey, try a general engineering place see what they would do it for. :idea:
vhpacer
Postby Zak » Wed Nov 16, 2005 8:09 pm
That was smoothened out ready for painting too, but it's about 4 mid sized holes, and a big bit under one of the rear windows.
Is that a fair price? or am I getting ripped for that price?
Zak
Postby Santa'sBoostinSleigh » Wed Nov 16, 2005 9:37 pm
Zak wrote:That was smoothened out ready for painting too, but it's about 4 mid sized holes, and a big bit under one of the rear windows.
pics of the rust would prob be good to help us to decide, but sounds steep to me
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Zak » Wed Nov 16, 2005 9:47 pm
I try get some pics up, thanks for all the help guys :D
Zak
Postby method » Wed Nov 16, 2005 10:27 pm
Sounds believable for a garage.
Id prep it your self, not hard. Pics would be good though.
PICS UPDATED DAILY
method
Postby Zak » Mon Nov 21, 2005 7:24 pm
I got some pics of it. 8)
Image Both sides :(
Image Both sides too :cry:
Zak
Postby Rick » Mon Nov 21, 2005 7:28 pm
If you want to save money remove window trim and window and cut out the rust and make a nice square hole, that way all they have to do is make a panel to suit and weld it in. If i wasnt so busy with my ae-85 I would give you some help.
Postby Zak » Mon Nov 21, 2005 7:32 pm
I can take the window out, but it makes it hard caus I have to bring the car over on the barge and stuff to get it fixed in auckland :?
Zak
