Need a new gearbox
Need a new gearbox
Postby ollieboy » Sat Nov 19, 2005 1:49 am
Well the first question I am asking is can a 5 speed gearbox fit in where a 4 speed was. I have this Starlet that I am looking at putting a new gearbox in because the old one causes excessively high fuel consumption.
Anyway the one in there at the moment is a 4 speed one.
I am looking to replace it with a 5 speed one but don't know if this is possible. How much do you think I could pick a gearbox up for or does anyone on here have one that I could buy that would fit? Also how long do you think it would take to replace a gearbox? I am looking at replacing the whole gear shizz with it as well like the clutch and flywheel cause the one I have at present is fuggered.
ollieboy
Postby overcast » Sat Nov 19, 2005 2:03 am
I'm assuming its an old Kp starlet with a K series engine, then yes a K50 (5 speed) will bolt straight into where the old 4 speed (K40) was .
overcast
Postby ollieboy » Sat Nov 19, 2005 2:33 am
overcast wrote:I'm assuming its an old Kp starlet with a K series engine, then yes a K50 (5 speed) will bolt straight into where the old 4 speed (K40) was .
I am not actually sure what model but I will check later on and see.
ollieboy
Postby Ae92typeX » Sat Nov 19, 2005 9:51 am
and if it is than its a pretty easy job you can do in a day/afternoon/evening if you can spin a spanner (and have all the bits required).
If fwd would take a little longer, but still a single day job easy.
Ae92typeX
Postby FrEsH » Sat Nov 19, 2005 10:40 am
its not a KP its an EP70 / 71 judging from the pics he put up of it in the multimedia section...FWD
FrEsH
Postby FrEsH » Sat Nov 19, 2005 10:41 am
its not a KP its an EP70 judging from the pics he put up of it in the multimedia section...FWD
stupid double post -_- sigh
FrEsH
Postby overcast » Sat Nov 19, 2005 12:55 pm
FrEsH wrote:its not a KP its an EP70 / 71 judging from the pics he put up of it in the multimedia section...FWD
sweet as, didnt actually have a look in the multimedia setion
overcast
Postby ollieboy » Sat Nov 19, 2005 5:20 pm
Yeah I just had a look in the engine bay and its an EP70.
So where would I pick up a gearbox from and how much do you think I should expect to pay?
Would a car dismantler have one, anyone know any good ones in CHCH?
ollieboy
