Whoops wrong oil filter!
Postby Boldy » Mon Nov 21, 2005 7:55 am
Did an oil change on my gf's fxgt 20v yesterday and noticed this morning that the guy from Albany toyota gave me the wrong part! The filter on the car has a part number 90915-10003 and is listed for 4A-FE etc and the part number for a 4A-GE is 90915-10004. Are the filters compatible? Damn should have checked the box before I put it on!
Boldy
Postby Adamal » Mon Nov 21, 2005 8:04 am
Well, the oil filter screws onto the block, and they're both 4A blocks so I don't see why there should be any problem.... If the shoe fits!
Postby Boldy » Mon Nov 21, 2005 8:18 am
yeah it fits fine, no leaking around the filter or anything. I was thinking maybe the 4AGE filter has better filtration or something, being the higher revver.
Boldy
Postby Adamal » Mon Nov 21, 2005 8:22 am
Yeah, you're probably right there.
I'd make sure to use some engine flush next time you do and oil/filter change. Just to be on the safe side ;)
Postby aesc » Mon Nov 21, 2005 8:23 am
I use a 10003 filter on my gtz even though the 10004 is listed for it. The only difference is that the 10003 is shorter. I have to use it because I don't have enough clearance for the 10004 because of my headers.
Its not a biggie
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Mr Revhead » Mon Nov 21, 2005 10:23 am
yep its fine..... depending on the year they list 10003 or 10004
the aftermarket equivalant is the same fitler...
10004 is bigger therefore my choice.
Postby Boldy » Mon Nov 21, 2005 10:29 am
sweet! At least I can get some km's out of it before it needs changing again. Cheers guys.
Boldy
Postby barryogen » Tue Nov 22, 2005 10:00 am
aesc wrote:I use a 10003 filter on my gtz even though the 10004 is listed for it. The only difference is that the 10003 is shorter. I have to use it because I don't have enough clearance for the 10004 because of my headers.
Its not a biggie
you got a heat shield or anything, or just cooking the filter for fun? :)
barryogen
2ZZ Guru in training
Postby aesc » Tue Nov 22, 2005 10:17 am
No I don't, I probably should get one made up but meh. I cant see it making a huge difference to the overall oil temperature in the engine.
EX AE101 owner
2013 Ford Focus ST
aesc
Postby barryogen » Tue Nov 22, 2005 2:19 pm
aesc wrote:No I don't, I probably should get one made up but meh. I cant see it making a huge difference to the overall oil temperature in the engine.
I was meaning more the oil temp inside the filter, heat oil and it will cake up, meaning the filter will be less effective at filtering.
barryogen
Postby pervert » Tue Nov 22, 2005 2:24 pm
barryogen wrote:heat oil and it will cake up
Oil gets pretty hot inside the engine anyway, doubt it would make that much difference... 8)
pervert
Postby Mr Revhead » Tue Nov 22, 2005 2:27 pm
what happens to oil that gets left on ya rocker cover for example....
how ever i dont think itll cake up in ya filter... but certainly using ya filter as a oil heater isnt the best idea! :lol:
Postby barryogen » Tue Nov 22, 2005 3:08 pm
Mr Revhead wrote:what happens to oil that gets left on ya rocker cover for example....
Thats what I meant...
Mr revhead wrote:how ever i dont think itll cake up in ya filter... but certainly using ya filter as a oil heater isnt the best idea! :lol:
with most things, there is usually a reason why they went with a shorter one. subaru used a short filter in my last car because it tended to cook if one that "fitted but was taller" was fitted. my mechanic fitted one that was taller... it cooked, the engine made an expensive sounding noise, blew a heap of smoke out of the engine bay(oil filter sits just next to exhaust)...
Thankfully it had just burst the filter and spilled oil everywhere, but it was caused by too much heat(it got sent away and checked out by some subaru service centre apparently)...
so thats my life story lol.
barryogen
Postby Mr Revhead » Tue Nov 22, 2005 3:10 pm
if oil is flowing and getting cooled as it should in a properly working system then it should be fine....
however there probably are some applicastions that are more prone to that than others
Postby CozmoNz » Tue Nov 22, 2005 3:12 pm
being a subaru probbaly didnt help :P
they have a bad habbit of suddenly dying for no reason whatsoever :D haha.
Rayne For President!
CozmoNz
Postby aesc » Tue Nov 22, 2005 3:16 pm
Yeah possibly, but change my oil and filter every 3 months or 3000kms so probably not much chance of it happening to me
EX AE101 owner
2013 Ford Focus ST
aesc
Postby barryogen » Tue Nov 22, 2005 3:17 pm
CozmoNz wrote:being a subaru probbaly didnt help :P
note that I no longer own the car, and have a toyota once more :)
barryogen
Postby SUBARUCONVERT » Thu Nov 24, 2005 1:28 am
That sounds like turd to me, did ur car have an aftermarket manifold or somthing?
SUBARUCONVERT
