Corolla XXX Rattles.
Postby shazeal » Tue Nov 29, 2005 10:08 am
Hi guys,
My gf's blacktop ae111 XXX corolla has a pretty mean rattle at the moment. But its really on and off. It sounds like a thin piece of metal rattling most of the time, but sometimes when you brake (doesnt have to be hard breaking) to a stop there is a scaping noise, and is sometimes followed by a loud grinding noise.
The rattle only usually occurs in 1st or 2nd when accelerating, or just rolling at 1.5-3k rpm and more so on bumpy roads.
I put the car up on some ramps on the W/E and had a look under the car but couldnt see anything loose. I gave the exhaust/floor panel guards look over and couldnt find anything loose enough to make that kinda noise.
Any ideas? I really cant see anything loose around the wheels/exhaust. Hoping someone might know of a common thing that would cause this on a blacktop.
Thanks.
Current - 83 Levin AE85 Notch.
Ex - 89 Sprinter - Red Top, 88 Levin - 4agze.
shazeal
Postby Mr Revhead » Tue Nov 29, 2005 10:23 am
checked ya brake pads?
Postby TRD Man » Tue Nov 29, 2005 1:44 pm
Backing plate bent and scraping on rotor?
Or stone lodged between rotor & backing plate?
Have you jacked the car up to find which wheel it's coming from?
TRD Man
Postby Mad Murphy » Tue Nov 29, 2005 2:52 pm
I had a similar problem, exhaust bracket loose as I recall.
1989 Supercharged AW11, 1981 Sprinter GT, 1991 Primera s**tmobile.
Facelift AW11 Parts Wanted!
Mad Murphy
