The gearbox is coming out in a couple of days due to the following problem.....
I backed my Marino out of the garage. It backed out ok, but when I tried to drive forward down the driveway it wouldn't move... the engine stalled. Hmmmm, restart, move revs, let the clutch out in first, stall, Hmmmm, restart, select reverse, let clutch out and it moves backwards normally. Hmmmm!! There must be a Gremlin jamming the diff like a ratchet!
Background:
Ewan (10k20v) helped me transfer the whole front subframe (subframe, suspension, C52 gearbox and 20v silvertop) from my trueno donor car into my Marino (siezed engine,C50). The donor Trueno had been hit hard in the right rear wheel when parked on the side of the road, everything else was OK.
1 week ago:
Got it running (after minor hassle with fuel pump relay operation). Drove the Marino to the post office and got 3 months rego (rego was on hold). Drove it about 15km it total. During one gearshift from 3rd to 4th it made a loud clunk but otherwise ok so I though nothing of it.
Today:
Finished putting the disks brakes on the rear, sorted the exhaust out (thanks Lee) and replaced a broken stud on a front hub. Then I took it for a test drive to get the rust off the rear disks. I checked that it revved out ok and then did about 10 hard stops from 100kph. On my way back into town I shifted from 3rd to 5th at about 55kph, there was a tiny clunk that sounded like synchros, I thought nothing of it.
Got home, parked in the garage, vacuumed the interior and refitted the rear seats.
Started the Marino and backed out of the garage to go and see Ewan at his work and show him the finished car.
Open garage, get my jack, jack up the rear of the car... wheels turn freely either way.
Jack up front of car, check it is in neutral, turn one wheel forwards, other wheel turns backwards. Turn the wheel backwards, other wheel stays still.
Start engine (front wheels still off the ground), select first let out clutch, engine stalls, restart engine, select reverse, let out clutch, wheels turn backwards. I call Ewan to pick his brains, he can't think what it could be.
I then find that if I turn a wheel backwards enough time the wheel can turn forwards normally. I drop it off the jack and try to drive it into the garage so its out of the way, it oes forwards about 1m then stops. I back it up as far as I can then try to go forwards, it moves so I keep going until its in the garage, ready to be dealt to!
My theory: When the donor trueno got hit it was probably in gear, this has broken something that is now floating around in the gearbox. This broken bit has become jammed between the case and the crown wheel part of the diff. If I go backwards the bit just bumps up over the crown wheel teeth. Going forwards it jams between the crown wheel teeth and the diff housing. I dont really fancy having the whole gearbox lock up on me at 100kph so out it comes! Bugger! Just sold my other C52 last weekend!!.. I will have to get the synchro fixed on my C56 that is sitting around and put that in.
Ken
Ham
021 408 863
