Hi
Im looking for a non power steer rack for my ae85 and need to find one that fits .
The obvious is an AE85 non power rack but good luck finding them.
so I heard that an AE70 might fit is this true .Any help would be great.
Cheers.
crispy'86 wrote:AE70 and KE70 should fit into the mounts on the crossmember.
fangsport wrote:crispy'86 wrote:AE70 and KE70 should fit into the mounts on the crossmember.
only if you also have the correct crossmember, as the power steer rack needs a bigger clamp on the R/H/S.
find a rusty KE70 and get the crossmember as well. cut the rack mounts off and zap them onto a AE86 crosmember. alternatively, find a TE71 crossmember and rack, as the engine mounts are very similar.
Users browsing this forum: Google [Bot] and 20 guests
