Caldina Boost Guage
Caldina Boost Guage
Postby 20v_rollaboy » Sat Dec 24, 2005 10:14 pm
Hey there, my mate just bought a Caldina GT-T and wants to put a boost guage on it
ive had a look on the manifold but cant find any siutable places to put the piping, is there anywhere else i can put it?
or do i just drill and tap a hole and put a nozzle in there?
thanks for any help
20v_rollaboy
Postby sergei » Sat Dec 24, 2005 10:27 pm
just T into one of the vacuum tubes on the manifold (fuel pressure regulator will be fine as long as it goes on top not on one of the runners like in some cars)
Postby 20v_rollaboy » Mon Dec 26, 2005 7:03 pm
hay thanks have the boost guage working now but i cant find a hole in the firewall to run the piping :?
could someone here with a caldina please share where they ran theirs
thanks
20v_rollaboy
Postby adikt » Mon Dec 26, 2005 8:56 pm
most cars tend to have a rubber bung where the main loom runs through, quite often near the pedal box, or just behind/below the steering wheel
adikt
Postby Adydas » Mon Dec 26, 2005 9:02 pm
Agreed look just behind the Plenum area about 30cm Down / deep. Your bound to find something there
I ran my boost guage line though where my Accelerater cable goes i think it was.
Have a look there Will be something there.. just grab a screw driver and jam a hole in it.
Adydas
Postby 20v_rollaboy » Mon Dec 26, 2005 9:14 pm
yea we were just gonna do that but just wanted to ask if there was anywhere else it could go through that was a bit easier
but thanks anyway
20v_rollaboy
Postby Inane » Thu Dec 29, 2005 8:19 am
i just ran mine around under the panelling,
I didnt run through the hole in the firewall as thats a hassle. (and I havent fully decided on my permanent layout... so didnt want to waste time before i have)
but that works well for me.
can post pics if you want.
Inane
Postby 20v_rollaboy » Thu Dec 29, 2005 12:26 pm
pic would be cool thanks
and how did you wire up your VSC switch? what does it do? (is that like a traction control thing?)
20v_rollaboy
Postby Inane » Thu Dec 29, 2005 1:16 pm
20v_rollaboy wrote:pic would be cool thanks
is your mates Caldina a Manual? or a tiptronic which is 2000+ (and a GT-TS)?
if so VSC does not apply
if its one of the tiptronics then it has vsc (possibly has a sticker saying VSC on the back window)
VSC = Vehicle Stability Control
yes its a traction control thing and much much more.
my switch turns it on and off.
Inane
good place to put your boost guage hose
Postby PhilSawtell » Wed Jan 11, 2006 3:11 pm
I own a gtt caldina and what i did was just put a junction in between one of the map sensor hoses seemed to work fine
PhilSawtell
Re: good place to put your boost guage hose
Postby fivebob » Wed Jan 11, 2006 3:14 pm
PhilSawtell wrote:I own a gtt caldina and what i did was just put a junction in between one of the map sensor hoses seemed to work fine
Not a good idea. It's best to leave the Map sensor on it's own vacuum circuit and run the gauge off a different port, like the BOV trip line.
Postby 20v_rollaboy » Thu Jan 12, 2006 12:28 am
its a tiptronic one, and does the switch for VSC come standard? or aftermarket?
20v_rollaboy
Postby Inane » Thu Jan 12, 2006 9:39 am
the switch for the vsc is definately after market.
took me about 6 months of hard going to work out how to turn it on and off.
in the end the answer was easy though!
Inane
Postby snwtoy » Thu Jan 12, 2006 3:34 pm
I used a brass T into the line going into the bottom right hand corner of the right hand end of the plennum.. Cost about $10 for parts. Can't remember but it ould be the bov line?
snwtoy
Postby Santa'sBoostinSleigh » Thu Jan 12, 2006 3:43 pm
snwtoy wrote:I used a brass T into the line going into the bottom right hand corner of the right hand end of the plennum.. Cost about $10 for parts. Can't remember but it ould be the bov line?
depends which way you are looking at the car :P
blue one = bov line
Image= where my gauge is connected (not by me, by previous owner)
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby snwtoy » Thu Jan 12, 2006 4:29 pm
blue one = bov line
BOV line is the one I used then.. seems to work ok.
snwtoy
Postby BZG Wagon » Thu Dec 20, 2007 9:41 pm
Where have you guys mounted your boost gauges?
I was thinking the bottom of the A-Pillar as I cant thing of anywhere else suitable. I kinda like not having after-market gauges & stuff stuck to my dash / steering wheel.
BZG Wagon
Postby postfach » Thu Dec 20, 2007 9:49 pm
If you can wait until tomorrow, I'll go take a photo of where it's mounted in my mates GTT. It almost looks like it was meant to be there from factory. Because I don't have a GTT, I couldn't tell you off the bat exactly where it is, so I'm really not very helpful unless I show you a picture :P
postfach
Postby BZG Wagon » Thu Dec 20, 2007 10:21 pm
postfach wrote:If you can wait until tomorrow, I'll go take a photo of where it's mounted in my mates GTT. It almost looks like it was meant to be there from factory. Because I don't have a GTT, I couldn't tell you off the bat exactly where it is, so I'm really not very helpful unless I show you a picture :P
Thanks - that would be awesome!
I'm in no rush - just noticed Repco were selling some cheap 2" gauges & I want a place in mind which I'm happy with before I buy one.
BZG Wagon
Postby postfach » Thu Dec 20, 2007 10:33 pm
BZG Wagon wrote:Thanks - that would be awesome!
Sweet man, I'll get a photo and check which size his is as well.
postfach
