removal of pilot bearing in crank
Postby KE20 » Mon Jan 02, 2006 10:33 am
whats the best way of removing the pilot bearing in the crank,the one in my engine if buggered, how do i pull it out?
Garage Dori
KE20
Postby BBBrad » Mon Jan 02, 2006 2:20 pm
Use the special puller tool. Or if you aint got one a good trick is to fill up behind it with grease (pack it solid) then with a bolt or punch or something thats a tight smooth fit in the center of your bearing, hit it through and it will hydraulic itself out of the crank, grease cant compress.
Good luck.
Been known to weld a nut to them also and use a slide hammer for the stuborn ones.
My new car...99 mr-s
BBBrad
Postby Grrrrrrr! » Mon Jan 02, 2006 2:23 pm
pack the area behind the bearing full of grease then put a bar/bolt etc that fills the ID of the bearing pretty well and hit it with a hammer.. the hydralic pressure should pop it out.
BTW safety glasses and overalls are required.. you'll get grease and shite everywhere.
Grrrrrrr!
Postby KE20 » Mon Jan 02, 2006 2:24 pm
i dont have a special tool, but i tried the grease on a different motor once before,and i just poped the dust cover bits out and grease went thu the whole bearing, i never did get it out.
Garage Dori
KE20
Postby spencer » Tue Jan 03, 2006 9:42 am
KE20 wrote:i dont have a special tool, but i tried the grease on a different motor once before,and i just poped the dust cover bits out and grease went thu the whole bearing, i never did get it out.
same happened here only works well for the brass bush types I find. try the slide hammer I made a small one up for this job
spencer
