TRD001 wrote:Silvertop Conrods
2mm Or Thicker Head Gasket
TRD001 wrote:I don't currently have LSD and Im Not too sure I was going to use the standard Pistons? Not too sure good point tho, I am lead to belive that the BT Pistons would be ok. Is this right?
rotorchiki69 wrote:tdo4 is a small turbo and runs outa puff at about 5000 rpm ON A BIGGER ENGINE id go for a big 16g tdo5 from an evo3 make good power FROM ABOUT 4500 ONWARDS
TRD001 wrote:I was looking at some aftermarket forged pistons, I was under the impression that the 0.8 mm were no good for turbo application, The TODA belt is $60 more than original plus it's heaps sronger, I also am looking at the link + engine managment.
The engine + gearbox is out of A 1997 5spd carib, So is this a BZ-V?
What type of head gasket should I be looking at then?
che che
Mr Revhead wrote:yep do the pistons, NOT a thick head gasket.
